Where to monitor V6 engine coolant temp? - MG-Rover.org Forums
post #1 of 2 (permalink) Old 21-05-2010, 22:12 Thread Starter
Car: Land Rover Freelander
Id like to monitor the temperature of my 2001 Freelander V6 coolant (rover kv6 2.5L). Ive bought a device which has 2 temperature sensors. I plan to use one to measure the coolant coming out of the thermostat, flowing towards the top radiator intake. Been advised the coolant thermostat only opens when the engine is hot, to pass water into the radiator for cooling. Is there a better place to monitor the coolant to get the real coolant temperature, all the time?
As the device has 2 temp sensors, is there another temp reading, which would be helpful to monitor?
Hippo is offline
post #2 of 2 (permalink) Old 22-05-2010, 00:58
Car: Transit T280 100bhp, Diesel Focus, Kubota B6000 Tractor & ZS180 project
remove your underbelly tray and look up at the front of the engine between the nearside of the exhaust manifold and the rear cam belt cover, you should see a little plate with 2x 8mm bolts holding it in. the mg zs 180 has an additional coolant temp sensor fitted here and as its on the cylinder head coolant circuit you will have very accurate coolant temps.
ill take some photos tomorrow for you
2bellys is offline
Engine coolant temp sensor part no. mxb59307 MG ZS / Rover 45 & 400 18 16-08-2012 06:29
Engine Temp 2.0 V6 pat hanley MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 06-03-2010 10:44
engine coolant temp sensor Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 20 12-01-2008 19:11
engine coolant temp sensor changed Deano MGF and MGTF (Sponsored by MGFnTFBITZ) 8 13-11-2007 13:41
Coolant Leak \ Engine Temp fatcatbristol MGF and MGTF (Sponsored by MGFnTFBITZ) 2 03-09-2007 17:01
