Coolant Loss/Heater Problems - MG-Rover.org Forums
post #1 of 4 (permalink) Old 14-11-2016, 18:04 Thread Starter
Car: Rover 100
Hi guys,
I have a 1997 Rover 114 SLI,
My last posts on here were about a coolant loss problem last summer, in the end even though it wasn't conclusive I got the head gasket and water pump changed. That was last July and since then everything has been ok. However last week when I was driving and the car was up to temperature it started getting cooler, the temperature gauge dropped which has never happened before which I found odd. Nothing else happened so I continued using it, yesterday I drove the Metro to the NEC for the classic car show, I live in Leeds so a decent 200 odd miles round trip but again it was fine.
Then this morning on my way to work when the car was up to temperature I put the heater on full heat and it was only blowing cold air, when I finished work and the engine had cooled right down I checked under the bonnet and the expansion bottle was pretty much empty. I have spoken to the place that did the head gasket and I am taking it back to them at the end of the week but in the meantime has anyone got any ideas what the problem may be please? I am dreading another head gasket problem based on the bit of research I have done on the various forums so any help would be most appreciated.
Thank you,
Thomas
LUFC1992 is offline
post #2 of 4 (permalink) Old 14-11-2016, 19:33
Park on a sheet of card and see if you can see where the leak is. It may not be HG, it could be IMG, Water Pump, loose pipe or seal etc.
post #3 of 4 (permalink) Old 14-11-2016, 23:52
Car: F. Fiesta 1.6 ECOnetic
Read Hottubrepairer's excellent How to on this issue- the answer is there but if you cannot detect leak by using gnu's advice above, it's a process of elimination I'm afraid. Good luck
david.anthony is offline
post #4 of 4 (permalink) Old 15-11-2016, 00:49 Thread Starter
Car: Rover 100
Thanks for the replies.
I managed to have a look in the dark with a torch and thankfully it appears that a hose has split. So hopefully once I find the exact one and replace it, then fingers crossed It'll be alright.
Cheers guys
LUFC1992 is offline
MK2 ZS 180 coolant loss and heater problem badass180 MG ZS / Rover 45 & 400 6 10-11-2013 17:29
Loss of Coolant/ Heater.... devm69 MG ZR / Rover 25, 200 & Streetwise 3 27-12-2011 17:24
Slow coolant loss - heater bypass? ourmark MG ZS / Rover 45 & 400 9 28-01-2011 11:09
Coolant loss, Heater kicking out cold air, yet no HGF Friggerpants Diesel Forum! 11 06-06-2009 21:56
214 coolant loss problems R8Andy MG ZR / Rover 25, 200 & Streetwise 4 19-12-2007 17:55
