Rover 115d cooling fan electrics - MG-Rover.org Forums
post #1 of 2 (permalink) Old 10-01-2017, 18:29 Thread Starter
Hi
I've got a Rover 115d and I'm a bit stuck.
Cooling fan has stopped working.
Fan works with 12V
Temp gauge works fine
Fuses are fine
So must be knackered fan switch.
But
Theres 2 fan switches on the rad, and 2 temperature sensors on the thermostat
I'm baffled. What are the second set of sensors for?
The Rover 100 Haynes only covers petrol, which have 1 of each sensor
The Peugeot 106 Haynes covers the diesel engine, which has 1 of each sensor in French spec.
Any ideas?
Slughead91 is offline
post #2 of 2 (permalink) Old 11-01-2017, 14:29
Usually on the thermostat one sensor (single wire sensor) is for the dash gauge. A second two pin sensor is for the ECU.
On the radiator you may find the thermostatic switches control two speeds for the fan. (Or on many rovers the ECU controls the fans at two speeds). Sorry not familiar with the diesel.
If you unplug the two pin thermostat sensor does the fan run?
If you bridge out the radiator sensor does the fan run?
Rover 75 cooling fan pwsheldon MG ZT / Rover 75 (Sponsored by Rimmer Bros) 10 30-11-2011 03:10
Rover 75 Cooling fan on to much.. Faulty or ...? marculus1971 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 18-01-2010 22:23
Rover 75 2.0 V6 Cooling Fan amrover75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 17-10-2009 07:36
Rover 75 Cooling Fan Needed!! Ramjet Wanted 2 21-07-2007 11:40
Rover 75 cooling fan problem laser558 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 13 28-05-2005 14:21
