MG3 Clutch getting stuck down - MG-Rover.org Forums
post #1 of 14 (permalink) Old 19-05-2015, 19:20 Thread Starter
Car: MG ZS180, MG TF 135, Did own: MG ZS 2.5 V6, x2 ZS 120's, Rover 220GTi, x2 Rover Coupe's, MG Metro
We have a 15reg MG3 style lux from new with 2,680 miles done. The clutch got stuck down yesterday when attempting to pull away in first gear and my wife had to pull the clutch back up manually. She said that clutch had pressure when pulling it back up, the same amount as if you were pushing the clutch down. Only did it once yesterday and we did go out in the car later. She went to work this morning and went to pull away on a hill near home, clutch got stuck but this time on bite point with first gear engaged. Same fix, manual pull up with the same pressure as mentioned above.
We phoned our MG dealer and reported the fault but they have never heard of this issue. I know there is someone on this forum that had the same issue but sadly the thread ends with no answers on the cause. The dealer has said that they need it to do it all the time to be able to fix it, thanks MG .
Has anyone any ideas? Had or got this issue with their MG3?
JimmyCoupe is offline
post #2 of 14 (permalink) Old 20-05-2015, 12:17
Car: Mini (The real one)
MG3 Clutch sticking down
This is caused by an air leak into the clutch hydraulic system due to a leaking seal at the bulkhead join. It's an easy fix and if your dealer phones MG they will tell him what to do.
MG-W is offline
post #3 of 14 (permalink) Old 20-05-2015, 13:52 Thread Starter
Thank you very much. I had thought it might be an air leak but where the car is new I just didn't know. I am surprised the dealer reckoned they didn't know what this issue was though as normally its air in the hydraulic system or a broken bracket.
I will update once its sorted but again a big thank you.
PS is this a common fault on the MG3?
post #4 of 14 (permalink) Old 20-05-2015, 21:08
Car: scimitar ss1,1800 ti, Bond Bug,MG GS Exclusive, Nissan XTrail Tekna T32
this is the 2nd I have heard with this in as many weeks
littlechicken is offline
post #5 of 14 (permalink) Old 21-05-2015, 08:05 Thread Starter
Thanks for letting me know. Not ideal if the dealers don't know what to do. My dealer has now asked us to book the car into the service centre so they can review the issue. I hope they find the cause.
Will it continue to do this clutch sticking issue until its fixed or could it just be a phantom gremlin?
Problem gone away yesterday and her drive to work I hear was problem free.
post #6 of 14 (permalink) Old 21-05-2015, 09:22
It won't go away but it won't do it all the time. There is a rubber seal which fits in the join at the bulkhead, if you run your finger under it you will probably find a small amount of wetness. It's easy to find just trace the clutch pipe back from the gearbox.
MG-W is offline
post #7 of 14 (permalink) Old 21-05-2015, 09:28
It won't cure itself, but it won't happen all the time. There is a rubber seal at the bulkhead join which leaks, if you run your finger under it you will probably find a small amount of wetness. It is easy to find just follow the pipe back from the gearbox to where it goes through the bulkead.
MG-W is offline
post #8 of 14 (permalink) Old 21-05-2015, 10:41
Very informative thread for those with this issue.
Excellent job all
This is the first I've heard of it, but if this is the second time in 2 weeks as Littlechicken has said, maybe there is a dodgy batch of seals?
Beatonator is offline
post #9 of 14 (permalink) Old 24-05-2015, 14:52
Car: MG3 Style
I thought the others were due to a bush failing on the clutch arm, and someone mentioned corrosion on clutch arm due to condensation in the engine bay had contributed (I think it was Kerridges). I am no mechanic though and just relaying conversations from elsewhere.
3rd one I have heard of in the last few weeks now. Lowest mileage one though. The other 2 were 13k and 17k respectively.
Algo is offline
post #10 of 14 (permalink) Old 05-02-2017, 00:22
Can you show images of the problem
carmen ruiz is offline
post #11 of 14 (permalink) Old 05-02-2017, 06:22
They all do that.
MGNorman is offline
post #12 of 14 (permalink) Old 05-02-2017, 19:24
Car: MG 6 Magnette
Not all, but too many.
pwinters is offline
post #13 of 14 (permalink) Old 06-02-2017, 11:08
Originally Posted by MGNorman View Post
They all do that.
Has yours? if so what was the cure?
mgbob is offline
post #14 of 14 (permalink) Old 06-02-2017, 16:06
A quick Google appears to indicate that the 3 has something of a reputation for clutch issues.
Perry Stalsis is offline
Clutch stuck. pickledness MG ZR / Rover 25, 200 & Streetwise 5 01-12-2014 12:20
Is my clutch stuck? Hillmanminx MGF and MGTF (Sponsored by MGFnTFBITZ) 5 12-05-2012 05:29
my clutch pedals stuck up not down dawyer118 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 08-10-2011 19:49
my clutch pedals stuck up not down dawyer118 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 07-10-2011 22:21
is my clutch arm stuck glynk71 Rover 600 4 07-05-2005 13:31
