MG ZR 1.8 Turbo K in a ZR - What Do I Need? - MG-Rover.org Forums
post #1 of 6 (permalink) Old 09-03-2017, 15:29 Thread Starter
Hi guys,
I'm looking at putting a 1.8 turbo from a ZT/75 in my ZR and as I've not done anything like this before I thought it'd be a good idea to get some advice from people with some experience with this sort of thing. Basically I'm looking for anything I've missed from my shopping list and anything to look out for when doing the swap.
Shopping list so far:
- 1.8 k turbo complete engine from ZT 160 or 75 150
- Intercooler
- Modified piping and exhaust
- Different fuel regulator and boost valve - Kmaps has said they can supply those
- ECU remap by Kmaps
- PG1 gearbox - I'm looking at using the one from the ZR/25 TD for the longer ratios and higher torque rating and because it'll fit straight into my ZR, I assume it should fit being a PG1
- I've got a flywheel from an MGF 120 because I ideally want one lighter than the diesel one and once again I've assumed it'll fit as it's the same 'box
- Clutch kit
- Gear and clutch linkages, driveshafts and crank pos sensor for the PG1 as I've got a 1.4 with the IB5 at the minute - hopefully get them with the gearbox
- Possibly a VVC head if I can find one within budget
- I've heard I may need an upgraded fuel pump but haven't confirmed yet
That's what I've got so far but no doubt I've missed something or got something wrong so if I have could you let me know.
Tank Guy is offline
post #2 of 6 (permalink) Old 09-03-2017, 17:22
So, you've thought about the making it go faster bit, but what about the making sure it still stops bit? Do you want to put your life in the hands of the original 1.4 brakes?
Nicairius is offline
post #3 of 6 (permalink) Old 09-03-2017, 17:31 Thread Starter
yeah I am well aware the standard brakes are nowhere near capable for that sort of power and I will be upgrading to either ZR 160 ones or I might even have a crack at fitting the ones from a ZT however as I'm just a poor student it'll take some time to save up for either of those. In the meantime I'll either just have to go slowly or more likely I'll use my other ZR with the standard 1.4 engine because 1. it's more sensible and 2. it'll give my insurance time to come down a bit more so I don't have to rob as big a bank to insure the 1.8T.
Tank Guy is offline
post #4 of 6 (permalink) Old 09-03-2017, 17:48
What you really need are high lift cams and a set of intake throttle bodies
JOHNDQ is offline
post #5 of 6 (permalink) Old 09-03-2017, 18:00 Thread Starter
I like your thinking johndq . That may have to be done at some point but as Nicairius said brakes should probably come before even more power. Other those things am I about ok with my list or have I assumed wrong with some or all of it.
Tank Guy is offline
post #6 of 6 (permalink) Old 11-03-2017, 09:00
Asides a turbo and intercooler there is not much in extra weight and if he
sticks to the speed limits the 1.4 brakes will be fine but no harm in upgrading.
ROVER-25X is offline
t16 turbo car 620ti, 820 turbo, 220 turbo, etc skrib Wanted 3 29-12-2014 07:27
220 turbo/ bubble turbo polished stainless coolant rail SALE Marko For Sale 2 09-09-2011 15:58
fitting Rover 620ti turbo engine in 220 coupe turbo waynos Coupe 4 13-03-2011 08:59
T16 turbo wiring loom, standard boost controler, and turbo MetroMartin For Sale 1 10-07-2010 20:22
Rover 220 Turbo Coupe - 1995 - Packet (Uneven) TURBO Boost RichMann Coupe 8 19-11-2006 12:15
