DJ Wilmas Elise 111S S2 K series 1.6 Turbo - Page 12 - MG-Rover.org Forums
post #221 of 225 (permalink) Old 17-03-2017, 11:50 Thread Starter
Car: Rover 100
Finally getting the manifold made, this was the first attempt. I didnt like how much it stuck out and how the turbo was rotated
So second attempt looks a lot better
djwilma is offline
post #222 of 225 (permalink) Old 04-04-2017, 18:14 Thread Starter
Car: Rover 100
I now have the engine at home, I need to add in some oil and water pipes to the turbo and tidy up the breathers
JEK Fabrications made the exhaust manifold, oil return and also the brace which is rose jointed to allow movement due to heat.
I have also looked at the PCV breather and added in an oil pressure sensor (only comes with temp as std) and I need to seal all the joints
Then I need a TMAP sensor, Lambda sensor and stuck whether I ship it back to Specialist Components for mapping (where their normal dyno has a long waiting list) or book it in to make the engine mounts, get the engine running (2 month waiting list) on the std map and then drive to SC to have it mapped.
Ideally I ship it to SC and they get it back in 2 months and I get the engine installed but I don't think the way the project has run its that easy
djwilma is offline
post #223 of 225 (permalink) Old 16-05-2017, 19:47 Thread Starter
Car: Rover 100
Wow, you go away for holiday and leave the car with a man and **** gets done.......why didnt i do this before
Anyways, engine mounts are now made and engine is in the car. Turbo hasnt been fitted but i see no reason why it wont fit
Drive shafts fitted all ok, no rubbing (unlike duratecs so i am told)
No idea what this lug is but seems to be ok
Wiring next
djwilma is offline
post #224 of 225 (permalink) Old 17-05-2017, 13:19 Thread Starter
Car: Rover 100
Got the inlet and the turbo on today
Looks like it was meant to be in there, lot of room for the turbo and inlet was fitted in 30 mins as it went through the inspection hole
Wiring is now being sorted and I'll plumb in the water and oil hoses when home
djwilma is offline
post #225 of 225 (permalink) Old Yesterday, 22:04 Thread Starter
Car: Rover 100
The new fuel pump turned up today, big thanks to Gaz at Spitfire Engineering. This (small) pump should provide enough fuel for 500bhp at 3.5bar and Gaz kindly sent me a complete unit, i have to send my old unit back. I went for the Deutschewerks pump
This will save me a swirl pot, lots of fuel pipes and i dont need the Bosch Motorsport pump i had on the T series.
Hoping to have the car wired up to the ECU and Ford Loom next week
djwilma is offline
Lotus Elise S2 eddybrown Car related Photoshop and artwork 4 12-10-2009 04:36
k series in the lotus elise smokie999 MGF and MGTF (Sponsored by MGFnTFBITZ) 24 06-09-2009 18:56
MGF Trophy Vs Elise S2 111R KrisFX MGF and MGTF (Sponsored by MGFnTFBITZ) 64 29-08-2007 09:57
2004 lotus elise 111s engine gregbarton Others 6 15-07-2007 13:12
Lotus Elise S2 111s 2004 ( 04 ) Crash Damaged....!!!!! 4650miles mooncat For Sale 3 15-03-2005 23:18
