DJ Wilmas Elise 111S S2 K series 1.6 Turbo - Page 4 - MG-Rover.org Forums
post #61 of 222 (permalink) Old 01-03-2013, 09:39
Car: 2005 Jaguar S-Type R, 2016 Jeep Renegade Limited, 2003 Rover Streetwise SE
I reckon you'll go for more power
Why are the curves doubling back on themselves around 4,100 rpm on the latest printout?
t0m4ever is offline
post #62 of 222 (permalink) Old 01-03-2013, 19:35
Car: MG ZS180 :D
at a guess he has changed gear.
Drew
Roverdose is offline
post #63 of 222 (permalink) Old 04-03-2013, 15:55
Trader Supporter
Car: MGF, Alfa MITO, Volvo C70 and Maserati 3200GT 365bhp
Originally Posted by djwilma View Post
Thanks for the messages to say it's been emotional is an understatement.
The exhaust is in. Its 3" to after the cat then splits to twin 3" I did think about twin cats but heat and extra restriction put me off. Exit should use the std lotus tail pipes :-)
Now that's something!
TT MK7 exhausts for MGF and TF sold out next batch ordered. .
Neil Surrey Lab is offline
post #64 of 222 (permalink) Old 06-03-2013, 15:11
Car: zs saloon td x power in goodwood green
This is awesome, i used to follow your progress on mp with the metro so I'll be watching this closely. Top stuff!!
05ZR is offline
post #65 of 222 (permalink) Old 09-03-2013, 13:52 Thread Starter
Car: Rover 100
nope thats it for now 450bhp / tonne should be enough
Exhaust is something special
djwilma is offline
post #66 of 222 (permalink) Old 14-04-2013, 21:24 Thread Starter
Car: Rover 100
Well things are going a bit slower than I want but few snags on the way
The speedo is now working it has a stand alone pulse converter
The temp gauge now works, thanks arno and rotivator for the help its run off the dta and is now reading the correct temp
Afr gauge has been added to the centre consol
But the oil filter adaptor is leaking as its porous so needs to be replaced
We think the lack of revs is the head, the t series head isnt a wonderful design esp on the exhaust so I have purchased a ported head, some mechanical lifters and uprated springs and will run some piper 285 cams or a custom billet and try to rev to 8k
Car now needs to be shipped off to the body shop to get finished......summer is coming
djwilma is offline
post #67 of 222 (permalink) Old 20-04-2013, 20:30 Thread Starter
Car: Rover 100
So 382bhp and 371lbft just doesnt cut it, actually 6250rpm doesnt. C6 gearbox is just too short so need more revs, may loose a little bottom end but hoping to gain 1500rpm top end
So, i made some enquiries and came up with a plan of a ported and polished head with Mechanical Lifters, uprated single springs and some billet cams.
So i managed to get a head, its been ported but i only paid 200 for it, add to this the mechanical lifters and the springs (same as a k series) i purchased and all i needed was the billet cams
Spoke with Grant at gb-ent and he said 800 plus VAT, Piper said 1200 so i thought long and hard and in the end have sent some cams for a re-grind to Piper 285M via Drew at roverdose. Not ideal but i havent even driven the bloody thing yet !! In fact the only elise i have driven is a 340R, to the end of friends road and back, and a S2 of Junks, where i reversed 20 yards.
So the head malarky, will happen after the summer, car is on its way back as we speak from JDM Dyno in Cumbria so i can enjoy it as its nearly a year since purchase.
Pics of Ported Head, David Bailey eat your heart out
Exhaust
Inlet
Oh and the seats i have are blue and material, as the leather seats were sold, so i bought this drunk off of ebay........
They have a stamp saying 2002 so assume close enough for now
Plan is to get it re-sprayed and on the road within the next 4 weeks........
djwilma is offline
post #68 of 222 (permalink) Old 22-04-2013, 16:10 Thread Starter
Car: Rover 100
The car arrived home a day early, i was just trying to check in to a flight to Norway (which i missed), when the nice man called to say he was 30 mins away. Long story short my brother met the man and car is now at friends Lock Up awaiting being stripped and re-sprayed.......Starlight Black as per the original car
Engine in, only issue is the throttle cable hits the bonnet, so may need to adjust one of them.......
Nice big Dump Valve
Ickle Bit tight for the turbo but a ahem "Chimney" style heat shield, turbo blanket and baulkhead has been given the heat shiel treatment. Should help, undertray has a massive naca duct in it underneath and engine bay has a 4" in line fan to move air around when stopped or hot...
Charge Cooler, looks like a custom fit.....however its a Fiat Seicento std radiator, which is twin pass, with a modded end tank to take the 19mm tube to the charge cooler
Rear looks fairly std, as it has the original 3" Lotus ends :cool
Vibratechnics engine mount, and a few things in where the wheel arch should go so may need a little move around :beat
Inside the car we added the AFR gauge, the centre consol can do it but easier to look at the MTX, passengers knee may hit it so will remove the wifes right leg if this happens (y)
Front Clam with triple pass Pro-Alloy rad with 2 pull radiators.....charge cooler also has fans on back side for added cooling
AP 4 pot brakes look tiny against the 308MM discs, from a Vectra re-drilled to suit Elise Hub, all under std 111S wheels :o
Little, bad video, have explained to mate never to rev and switch off the engine again......or i kill him
http://www.youtube.com/watch?v=i2D81...ature=youtu.be
Sounds and footage is terrible so will get a better one later. Its has a resonance through the longer pipe, so blocking this quietens the exhaust.....just in case its too loud i can bung a bung or orifice into it
djwilma is offline
post #69 of 222 (permalink) Old 29-04-2013, 14:35
Car: Modified death trap
Loving your work sir..
Awesome!!
Dieseldestroyer is offline
post #70 of 222 (permalink) Old 02-05-2013, 02:37
Need a video of that dump valve lol.
ROVER-25X is offline
post #71 of 222 (permalink) Old 15-06-2013, 08:26 Thread Starter
Car: Rover 100
Well things slowed to a halt, promotion at work lots of travel and so on have meant the cars been on the back burner but finally getting things done
The throttle linkage needed changing as the m series inlet was fouling the rear clam, now fits underneath
Wiring is a mess so having this tidied up and the addition of a seperate fuel pump relay for the motor sport pump
But the main issue is the front clam. Bodge it and scarper painted it a lovely blue which had gone crazy. Tried to sand it off and it goes too mooch and clogs the paper as they just painted onto the original paint without sanding. Only way to remove is with a scraper which is time consuming
Hoping to have the car complete by end of june
djwilma is offline
post #72 of 222 (permalink) Old 16-06-2013, 21:12
Looking good.. Epic work Sir..
post #73 of 222 (permalink) Old 17-06-2013, 08:17
Car: MG TF 160 - Pearl Black
I was wondering what happened to this project only yesterday, thanks for the update and congratulations on the promotion too!
Kameleon is offline
post #74 of 222 (permalink) Old 18-07-2013, 21:02 Thread Starter
Car: Rover 100
Failure.......this is the word of the day but in the grand scheme of things, and after some soul searching and being told not to be grumpy "its only a car" i have come to terms with the MOT failure today !
It didnt fail on much, i couldnt find the drivers side mirror, the aim on one of the lights is low but worst of all the steering rack is buggered.
So basically the car looks like this now
It needs to be sprayed but my insurance company are threatening to cancel the policy so it had to be done this week.
Here it is on the MOT Bay at K-tec racing, passed the emissions no problems, but it ran out of electricity and has sprung an oil leak.....so off with the rear clam again !
But before all that went Pete Tong we took this video, not be driving as Scott cant use a camera its 20 seconds of your life you wont get back, but even i am thinking this doesnt exist sometimes !
http://www.youtube.com/watch?v=ohsSc...e_gdata_player=en&fs=1&rel=0&hd=1">http://www.youtube.com/watch?v=ohsSc...e_gdata_player&hl=en&fs=1&rel=0&hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340">
djwilma is offline
post #75 of 222 (permalink) Old 19-07-2013, 07:48
They are cancelling the insurance policy because it's not sprayed or because it failed the MOT?
Kameleon is offline
post #76 of 222 (permalink) Old 20-07-2013, 21:24 Thread Starter
Car: Rover 100
As it needs to be mot'd
djwilma is offline
post #77 of 222 (permalink) Old 24-07-2013, 13:57 Thread Starter
Car: Rover 100
Well i know the reason the rack felt ok but was horrible to drive / failed the mot
The casing was cracked on the passenger side close to the pinion.....
Luckily i ordered a new rack from the ever quick elise parts, went for the quick rack as it sounded cool so its fitted and feels so much better
Awaiting the plinth for the drivers mirror, apparently lotus only process orders on Wednesday so i have to wait till next week.....if anyone has a spare drivers side please let me know otherwise i will bodge something on for Friday as need to get it MOT'd or the insurance will be cancelled
djwilma is offline
post #78 of 222 (permalink) Old 28-07-2013, 18:41
Car: 04 TF 135
Awesome work
bensewell is offline
post #79 of 222 (permalink) Old 30-07-2013, 20:18 Thread Starter
Car: Rover 100
Car is now road legal !
Now to sort out lack of electricity and oil leak......exhaust manifold maybe leaking as well ffs
Then get it sprayed, then uprated links and geo
Then actually drive it !!!
djwilma is offline
post #80 of 222 (permalink) Old 31-07-2013, 13:32
Good job! Your insurance will be happy. Fingers crossed you find time to sort this soon sir.
Kameleon is offline
Lotus Elise S2 eddybrown Car related Photoshop and artwork 4 12-10-2009 04:36
k series in the lotus elise smokie999 MGF and MGTF (Sponsored by MGFnTFBITZ) 24 06-09-2009 18:56
MGF Trophy Vs Elise S2 111R KrisFX MGF and MGTF (Sponsored by MGFnTFBITZ) 64 29-08-2007 09:57
2004 lotus elise 111s engine gregbarton Others 6 15-07-2007 13:12
Lotus Elise S2 111s 2004 ( 04 ) Crash Damaged....!!!!! 4650miles mooncat For Sale 3 15-03-2005 23:18
