"The K-Series Head Gasket" - PPC Magazine technical article. - Page 2 - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 25 votes, 5.00 average. Display Modes
post #21 of 104 (permalink) Old 07-11-2008, 20:11
Car: rover 25 is daughters car
Evans and Halshaw (LEEDS) had replaced the head gasket on my rover 45 a few months before i bought it, the head gasket went again ! (probably was already gone when i bought it), i thought no problem it was under warranty, i gladly showed the warranty company the reciepts etc. from the earlier Evans and Halshaw HG job, trouble was it was clear to see they didnt replace the cylinder head bolts, as a result they reduced the ammount they should have paid out !!!!!!, so i was out of pocket without a leg to stand on !!!
tim
timmy toad is offline
post #22 of 104 (permalink) Old 11-11-2008, 06:42
Car: ZT CDTI+ 171 / ZT 1.8T 160
Send a message via Skype™ to hogwarzt
Cant believe they didn't change the bolts...makes me wonder if they actually changed the HG at all..cos there is no real easy way of checking...
hogwarzt is offline
post #23 of 104 (permalink) Old 11-11-2008, 06:55
Why would they want to replace the bolts if they were still within spec? They have enough stretch left in them to be reused several times.
1955diesel is offline
post #24 of 104 (permalink) Old 13-11-2008, 12:31
Unhappy Headgasket
My greatest fears have come to a head. The HG has failed, The funny thing is that my wife said the car interior wasnt getting warm at all and I wondered if the thermostat had stuck shut and caused the HGF....does this some reasonable???
hogwarzt is offline
post #25 of 104 (permalink) Old 21-11-2008, 22:37
Car: Rover 75 CDT Tourer Conn. SE
Experiences with Cortinas, a (very!) wet-linered Citroen BX- and even recently my XJ6 suggest a noticeably cool heater is a good clue to dropping engine water levels! All? heaters are set above engine level, so as water is lost, the higher heater matrix drains FIRST! Hence -cold heater! Used this warning to stop and refill the BX- every 50 miles or so! Never again!! Best. P.
TheBishop! is offline
post #26 of 104 (permalink) Old 21-11-2008, 22:46
The biggest cause of HGF on a K series is due to a coolant leak or lack of pressure in the cooling system.
This can be down to a pinhole in one of the hoses or steel pipes, a leaking water pump, a detached impellor on the pump, leaky rad (or heater matrix), or a faulty header tank /cap.
Normally if the thermostat sticks, it will stick open, resulting in overcooling (and a lack of heater). This normally won't cause HGF but will use more fuel.
The heater is on a bypass circuit, so water will circulate through the matrix whether the thermostat is open or closed. My Rovers generally had a nice warm cabin well before the thermostat opened.
HGF isn't as bad as all that. If the head is true, and the bolts are within spec, it's not too hard a job to DIY (or overly expensive). It is also worth upgrading to the MLS gasket and stiffened oil rail at the same time. Get a Haynes Manual and follow the instructions meticulously and you should be able to change the gasket easily.
cjmillsnun is offline
post #27 of 104 (permalink) Old 26-11-2008, 22:01
Car: 99 MGF 1.8 (Dynoed @137bhp) & Rover 25,1.4 (102 bhp actual)
Hi Hogw., water in oil gives 'mayo' (emulsification) so keep chasing Evan Halshaw. There is still a problem.
As preventitive measures on our MGF's, I insert the Tin alloy fuel cat in the tank which REDUCES the burn temp of unleaded by 150C in the cylinder head, attacking the root cause (HEAT build up) rather than playing catch-up, also I add Molyslip to the new engine oil (oil filter must be changed) to lower friction and thus heat production. Having had K series engines since 2000 in various MG/Rovers either I've been lucky or these steps work.
On a similar note, has anyone got any experience in using the '4 LIFE' coolant, as on the MGOC website? I'm seriously considering fitting SS pipes and 4 LIFE at the same time again as a preventitive measure which they claim lasts for 10 years.
gb.mgengtune is offline
post #28 of 104 (permalink) Old 30-11-2008, 18:54
il take this point to say thanks to all you bods on the forum with all the different views and guides that have helped me change my head gasket today!! seems to be working ok so far but its gonna be a git to flush out all the oil from the water system... the only fault i can find so far is a suction noise from the engine as its turned off, will have to look at this further! but like i said thanks peeps for adding your info it really does help.
1.8 impression s with 51k!!
britgreen45 is offline
post #29 of 104 (permalink) Old 30-11-2008, 19:10 Thread Starter
Mmmm....Rover..
technozen's Avatar
Suction sound is normal, don't worry about it.
technozen is offline
post #30 of 104 (permalink) Old 15-12-2008, 15:22
This little video maybe of use with this thread, MLS Gaskets explained; http://uk.youtube.com/watch?v=FeiMY9ezkqk
ampthetex is offline
post #31 of 104 (permalink) Old 24-03-2009, 15:09
Car: 45 1.4 impression
Originally Posted by cjmillsnun View Post
God no Please don't use this.
I've just bought this on recommendation from several people for my 214sli!
Why not use it?? My car's HG is starting to show signs of wear, a bit of creamyness etc, now there's an intermitent water leak-probably the pump. I just want to prolong the life for a few more hundred miles, the guy in the car parts shop said that this'll do the job!
I'm confused!!
maddy's mum is offline
post #32 of 104 (permalink) Old 26-03-2009, 15:06
Car: MG ZT-T+ CDTi Auto
I'm confused!!
Worked damn well for me for over 10,000 miles!
DMGRS is offline
post #33 of 104 (permalink) Old 24-04-2009, 19:04
Thumbs down K Seal - Delaying the inevitable!
Originally Posted by jonspurs View Post
You could try out k-seal...has worked for me for a while...but it's losing water again slowly...!
I spent a long time suffering with an iffy gasket and used K-Seal, it worked for a while but once coolant = oil and oil = coolant I went for it and changed the gasket myself.
Wish I had done it long ago, easier than expected and done for under 100 quid!
madacksman is offline
post #34 of 104 (permalink) Old 25-08-2009, 09:00
K seal, if its as good as it calims it will damage the rest of the cooling system but more than likely it just doesn't work.
It will not bridge the gap when an elasomer bead has failed.
HGF occurs when the engine has over heated, you must trac the source of that over heating and cure it, MLS gasket is simply more robust than an Elastomer one but MLS ones will fail if the primary cause of HGF still exists.
Liner heights are critical, not only must they be within tollerance but if using MLS critically they should be very consistant.
I cant emphaise enough times we get jobs in that others have already tried and failed with because they short cut.
Save money, do it properly and do it once. If you are paying someone else like us it will be expensive but time costs.
I haven't read the artical but notice from pics that refreshingly they have picked up on the porosity issues that the K series head suffers from.
Rally Matt is offline
post #35 of 104 (permalink) Old 25-08-2009, 10:24
Car: Jaguar 3.0 S type.
Send a message via MSN to Cap'n ZS
K seal will not damage the cooling system due to the nature of how it works. Its not a sludge type suspension like rad weld etc, but a solution in the water of a sodium silicate. It works by been activated by temperature above 115 deg C so will not cause any issues. As for its use with headgaskets, well it will temporarily fix a leaking fire ring (just about good enough to flog a car through an auction), its useless at repairing a failed elastomer (no heat to activate it at the failure point) but where it is brilliant is if you suffer a liner seal failure. Due to its nature not only does it stop coolant getting into the oil but it solidly seals the liner into the block and increases the torsional ridgity of the engine. We have several 1.8 turbos that continued to loose coolant into the oil after headgasket repair that have been permenantly cured with k seal over the last 18 months. It has its uses in the right conditions.
Cap'n ZS is offline
post #36 of 104 (permalink) Old 30-08-2009, 21:57
Car: rover 416 tourer
Wink
I've done two head gaskets on the Rover K - not too difficult, but the second time the head had marks around the fire-ring, so I went to a scrappy, took several heads off (doesn't take long with experience) and took the flattest I could find - two years on and the car still runs fine.
Incidentally, the lass who owned the second car was VERY grateful...
PoorDriver is offline
post #37 of 104 (permalink) Old 30-10-2009, 21:48
Car: Other Rover
My Dad has just had 2 head gaskets go in ONE day! First the Rover 75 2.5 V6 in the morning then the Rover 25 1.6 in the evening.
So we intend to fix them but are there any particular kits to go for? I understand Lotus did a kit with a thicker gasket. Does it work?
...I do hope he can still talk my Mum into buying an MG TF....
MGROVERnut is offline
post #38 of 104 (permalink) Old 21-12-2009, 12:44
I'm quite interested in the theory of coolant pressure in the coolant system.
The MG Rover manual I have for my ZR says, fill the header tank up to the maximum mark but I've always kept mine half way.
Whats best? Max or half way between min and max?
Vi7ia7e is offline
post #39 of 104 (permalink) Old 11-01-2010, 20:30
Considering how sensitive to overheating the K series head gasket is I'm appalled at the way some people on these pages treat their cooling systems. The Forum is thick with reports of long standing coolant loss issues, systems frozen due to lack of antifreeze, discoloured coolant and the like. Quite a few people also report boiling up and then driving home "carefully" without refilling the system.
Thanks for the rant!
post #40 of 104 (permalink) Old 12-01-2010, 08:50
Car: 25, 75, MG ZR and MG TF
Half way between min and max is the maximum mark.
pete l is offline
K Series Head Gasket article BlueAgave MGF and MGTF (Sponsored by MGFnTFBITZ) 0 13-05-2008 12:46
Enjoying MG Head Gasket article JustinB MGF and MGTF (Sponsored by MGFnTFBITZ) 15 01-10-2006 21:14
K series head gasket!! philip Others 22 30-01-2004 20:09
