Not to sure where to put this - How to use Bradex easy start? - MG-Rover.org Forums
post #1 of 5 (permalink) Old 20-11-2007, 00:28 Thread Starter
Car: Rover 100
Anyone used this before? The instructions on the back read "Spay into air intake" well what goods that going to do? also do I take off the air filter and spray up there or do I just waft it up the pipe near the head light? How does this magic stuff supposed to make the car start when the problem is the engine is to cold and damp?!
old-boy-young is offline
post #2 of 5 (permalink) Old 20-11-2007, 00:31
Car: Punto/saxo,others.
Send a message via MSN to mickh
No ,take the filter off first.It "primes" the engine.
mickh is offline
post #3 of 5 (permalink) Old 20-11-2007, 00:43
Car: FJ1100 STREET FIGHTER
As said, undo the air-box and give it a 5 second burst up the air-intake, put the can to one side and immediately attempt to start the engine, before it evaporates out of the system. Do not use while someone else is cranking the engine as a blow back could ignite the can. I use butane which is equally potentially dangerous.
Why would it work?....... when the ignition system is damp, the spark is often weak, this mixture catches easier, it's as simple as that. Then as the starter motor is no longer cranking, more current goes to the ignition system and it's able to ignite with the normal petrol/air mixture.
BIGGUNS is offline
post #4 of 5 (permalink) Old 21-11-2007, 00:20
"How to use Bradex easy start?" Basically; Don't, except in dire emergencies. It is simply ether which ignites very easily, but has the drawback of drying out the cylinder liner if used frequently. With constant use, engines become addicted to it and won't start without it. Further continued use can lead to extreme difficulty in getting it started at all. Best advice is to rectify the reason for poor starting in the first place - replace the battery/get the engine tuned etc.
post #5 of 5 (permalink) Old 21-11-2007, 00:42
It's only intended for emergency use.................
BIGGUNS is offline
MG ZT CDTi won't start without Easy Start gaznav MG ZT / Rover 75 (Sponsored by Rimmer Bros) 31 20-08-2008 23:22
420 dt will start will not start davvy1978 Diesel Forum! 3 01-04-2008 14:35
wont start easy on first start up,smoke gligur MG ZR / Rover 25, 200 & Streetwise 2 31-07-2006 10:25
indoor fan start running after several minutes after engine start vervoorm MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 24-07-2006 08:28
hundreds of illegal programs in RUN and start up? an easy way to delete? SDI200 PC Gen Chat & Help 11 25-08-2005 23:50
