P0300 and P0170 when cold. - MG-Rover.org Forums
post #1 of 2 (permalink) Old 11-05-2017, 08:14 Thread Starter
Car: 2004 stepspeed
Hi Guys any suggestions? 2004 Stepspeed. On cold start the engine appears to over fuel (I can smell it). If I leave it idling the engine light comes on with P0300 and P0170 Multiple Misfire and fuel trim. If I drive the car away without letting it idle no fault appears. When warm it idles without a problem. I've no way of checking the fuel pump but as it runs well hot I've assumed that to be O.K. I've ruled out the cam sensor for the same reason.
I've changed, plugs and coil, fuel and air filter, MAP sensor, Inlet air intake valve, no obvious problems with hoses. When running the O2 sensors look fine. I'm running out of ideas any suggestions?
Ian Harrison 2 is offline
post #2 of 2 (permalink) Old 14-05-2017, 20:46
A P0170 (fuel trim, bank 1) is very frequently associated with a lambda sensor fault (bank 1 indicates the one in the exhaust downpipe below the manifold I think). Overfuelling is a common symptom when this sensor is not providing a correct signal to the engine ecu. It may be a poor contact in a connector, damaged wiring or a faulty sensor.
fault codes p0300 and p0313 getroverworking MG ZR / Rover 25, 200 & Streetwise 7 06-03-2015 19:54
P0300 fault 161racer MG ZR / Rover 25, 200 & Streetwise 2 12-04-2013 10:34
Fault code P0300 chriswatton MGF and MGTF (Sponsored by MGFnTFBITZ) 11 20-04-2012 17:19
Fault code P0300 - MG ZT 1.8T Luke MG ZT MG ZT / Rover 75 (Sponsored by Rimmer Bros) 18 15-01-2012 10:03
Fault Code P0300 Silver9 MG ZS / Rover 45 & 400 6 27-04-2011 05:58
