1.4 to 1.8 vvc conversion??? - MG-Rover.org Forums
post #1 of 3 (permalink) Old 13-06-2011, 15:18 Thread Starter
Hi all, my 1.4 has finally given up hope n gone bang and is going to cost to much to repair so i was having a look and noticed i can get a 1.8 vvc pretty cheap, and wiring loom cheam along with ecu aswell but what will i need exactly to do the conversion will the 1.8 vvc drop straight in or not?
any help and advice is much appreciated
thanks
mgxpower is offline
post #2 of 3 (permalink) Old 13-06-2011, 15:38
Send a message via AIM to Kelaroost
Done the conversion myself and I had to use:
pg1 gearbox
driveshafts
gear linkage
engine and gearbox mounts
Subframe.... or weld the mount onto the old sub frame like I did
engine
loom
ecu, 5as and fobs
If you are going to use the r65 gearbox thats already in the car then it's just a case of swapping engine, loom, ecu.
but don't expect the r65 to last very long.
I also upgraded the radiator and brakes.
Kelaroost is offline
post #3 of 3 (permalink) Old 13-06-2011, 16:37 Thread Starter
pg1 gearbox
driveshafts
gear linkage
engine
loom
ecu, 5as and fobs
is pg1 gearbox the 1 that comes with the vvc engine and what driveshafts will i need the ones of a 160bhp vvc 1.8 zr?
cheers matey
mgxpower is offline
Conversion of my TF from 1.6 VVC to 1.8 VVC DimTf160+ MGF and MGTF (Sponsored by MGFnTFBITZ) 35 23-01-2009 17:23
vvc to non-vvc solid cam conversion skanking pete Wanted 2 28-12-2008 22:19
VVC 145 to VVC 160 Conversion PERRY-MGTF MGF and MGTF (Sponsored by MGFnTFBITZ) 10 13-10-2006 09:14
vvc engine in non vvc mgf conversion mr_ixolite MGF and MGTF (Sponsored by MGFnTFBITZ) 6 12-09-2006 20:45
vvc conversion swebber23 Others 27 14-12-2005 08:12
