2000 W Rover 25 - leaking sunroof (electric) - MG-Rover.org Forums
post #1 of 3 (permalink) Old 23-11-2006, 18:18 Thread Starter
Car: Impreza Turbo, Focus diesel Estate, Rover 25 1.4.
Hi all,Could someone cast a bit of light on a question I have? my friend has a 25 which the sunroof has now started to leak in on. On closer inspection, the area where the outer seal bonds to the metal has been severely compromised by quite advanced corrosion, thus water seems to be leaking into the area before the drip tray and soaking the front centre-ish of the headlining.After looking in a few scrapyards, it seems just about any other sunroof panel from 25s and 200s ( I presume the 200 will fit? it looks to be identical) I find is afflicted with the same corrosion issue, is this a common problem for this model? Failing finding a non corroded ex-scrapper item, I was intending to find one with relatively little rust, carefully remove the seal, clean the rust out, and the mastik the seal back in place. Any suggestions though would be happily received!Has anyone else had this corrosion issue with the 200/25/ZR sunroofs? is the leak into the headlining caused by corrosion un-seated seal? it just seems the most likely cause!
SnapdragonGT is offline
post #2 of 3 (permalink) Old 23-11-2006, 18:20
Car: Other Rover
I had this. You need a new sunroof mechanism.
No use getting second hand, you need to buy new.
Best of British Rover had the unit for 99 when i got mine.
gmax is offline
post #3 of 3 (permalink) Old 23-11-2006, 22:01 Thread Starter
gmax,
Thanks for the reply, 99 sounds far more acceptable than the 200 plus I was quoted by Rover! Do you have a link for this best of british outfit?
Cheers dude.
How Do I - Fix My leaking Sunroof Seal - 200/400/25/45 Dr Dave How Do I - Answers To Common Problems. 39 16-08-2015 11:13
rover 25 (2000) sunroof fruitowl MG ZR / Rover 25, 200 & Streetwise 4 08-04-2008 13:43
Rover 213S Leaking Sunroof cumbrianrover Others 3 27-07-2005 12:18
Rover 214si Leaking Sunroof J888 NEY Others 9 09-03-2003 21:50
