Can you help with my leak... - MG-Rover.org Forums
post #1 of 6 (permalink) Old 19-05-2017, 18:59 Thread Starter
Hi all, I am finding it hard to identify where this is leaking from, possibly multiple places? I think it is engine oil as it doesn't have the nasty smell gb oil does but where the leaks are present would say otherwise. Nothing running down back of engine as the highest oily place is the plate that the reverse light switch goes into however, the n/s inner driveshaft joint looks oily as well? It is just a weep as nothing ever drips on the floor.
MGtom91 is offline
post #2 of 6 (permalink) Old 19-05-2017, 19:15
I would have suggested that's coming from the driveshaft seals but if your convinced it's not gearbox oil then must be dripping down from above and finding its way around the driveshafts and differential casing.
TipperMG is offline
post #3 of 6 (permalink) Old 19-05-2017, 21:33 Thread Starter
It may be gearbox oil but it doesn't smell like it. What about the reverse light switch, is there a seal under the plate where the connector is?
MGtom91 is offline
post #4 of 6 (permalink) Old 20-05-2017, 11:21
I agree - drive shaft seals...
post #5 of 6 (permalink) Old 20-05-2017, 15:39
If it is those then be careful and ensure you get the right size as sizes changed during production but I've no idea when though.
Should have said this applies to PG1 gearbox.
TipperMG is offline
post #6 of 6 (permalink) Old 22-05-2017, 08:53 Thread Starter
R65 gearbox. I have dropped the box to change the clutch and can confirm it looks like weeping from both diff seals. Had the correct one for o/s, although original is orange and my replacement is black but same size. N/s one has a metal ring where the shaft sits (TRX100201) , so have had to order one from Rimmers.
MGtom91 is offline
Diesel leak from leak off pipe Daz7595 Diesel Forum! 6 14-07-2015 10:48
Oil Leak and coolant leak? (Pics included) R25NWY MG ZR / Rover 25, 200 & Streetwise 4 20-03-2011 00:18
oil leak, exhaust leak, engine noise stevexyg Diesel Forum! 2 16-02-2008 11:38
oil leak coolant leak and mis-fire - great! mtm81 MGF and MGTF (Sponsored by MGFnTFBITZ) 7 18-04-2006 08:46
