changing water pump rover 25 - MG-Rover.org Forums
post #1 of 17 (permalink) Old 21-10-2010, 13:30 Thread Starter
Car: land rover freelander td4 and l series
just wondering have to change the water pump this weekend on the rover as its leaking when stopped now. also going to do new cam belt as well any info for this job ie lining the cams up atc how to relise the cam belt and also how to retention the belt when the new pump is on etc.
craig8661 is offline
post #2 of 17 (permalink) Old 21-10-2010, 14:51 Thread Starter
just to confirm its gone on the gasket face at the bottem these engines arnt known for cracking or anything there are they bolts seam tight but going to change water pump any way just need info lol.
ive got the rover manual on cd as well lol
post #3 of 17 (permalink) Old 21-10-2010, 14:55
1955diesel is offline
post #4 of 17 (permalink) Old 21-10-2010, 15:02 Thread Starter
hmmmm thanks 1955diesel.
now need to look under it again as obv that was not the water pump leaking then.
whats the plate for behind the bottem pully as it looks like water is def leaking from there.
post #5 of 17 (permalink) Old 21-10-2010, 15:07
If water is coming out from behind the crank pulley it probably is the water pump leaking. The pump is just above this, behind the plastic belt cover. Remove the upper cover and you should be able to see it leak.
post #6 of 17 (permalink) Old 21-10-2010, 15:09 Thread Starter
lol im stumped by the bolt down near the water pump cant get the spanner onto it and have not got a 8mm socket lol
post #7 of 17 (permalink) Old 21-10-2010, 15:49
Car: MG ZS MKII 120+
definately water pump leaking mate.
ScottishRover is offline
post #8 of 17 (permalink) Old 21-10-2010, 15:50
get yourself a 1/4 drive ratchet socket set, with various extensions and u-j's.
its quite tedious with limited access.
post #9 of 17 (permalink) Old 21-10-2010, 17:07 Thread Starter
lol and there is me with my half inch drive been and got a water pump so now 24 lighter of lol if the weather is not to bad tomorrow night will get it fitted. this pump has a rubber o ring do you use any gasket seal as well with it or just fit as is
post #10 of 17 (permalink) Old 21-10-2010, 18:11 Thread Starter
just orderd the cam locking tool at 6 better than the cam rotating and causing me more problems
post #11 of 17 (permalink) Old 21-10-2010, 18:32 Thread Starter
just seen that vid and it should be in stickys makes it alot easy than the book makes out. i have no problems drooping gear boxes out etc but i have a phobic of doing cam belts etc.
post #12 of 17 (permalink) Old 21-10-2010, 18:37 Thread Starter
is this cam kit any good mine has the auto adjuster
http://cgi.ebay.co.uk/Rover-25-1-4-1...item19bf86f3f6
post #13 of 17 (permalink) Old 21-10-2010, 18:44
Yes, both parts are to Rover OE spec.
post #14 of 17 (permalink) Old 21-10-2010, 18:46 Thread Starter
just to confirm as well the manual adjuster is compleatly different from the one in that kit.
mine has the bolt with the allen key hole in the bottem
post #15 of 17 (permalink) Old 21-10-2010, 18:48 Thread Starter
its ok just seen the print of in the manual.
the manual adjuster is a round part with the allen key and the auto is oval type with allen key.
mine is the same as the listing.
also whats the milage recomendation for the belts to be changed
post #16 of 17 (permalink) Old 10-05-2017, 18:36
how to change the water pump on the rover 25 l series, as I was able to remove the pump cover but I do not know how to remove the pump, it seems to me that the pump has a way to remove it without having to force the pump output
I need your help xda because it's my day-to-day use car
palmira is offline
post #17 of 17 (permalink) Old 12-05-2017, 06:39
If all the screws are removed it should come off. There are 6 retaining screws in total, with one behind the dipstick, iirc. It could be stuck on with sealant, so require some careful levering. See 3rd pic and text here for some further advice...
Rover 214 Overheating – Radiator, Cooling Fan and Water Pump Replacement - MG-Rover.org Forums
changing the water pump richardbell MGF and MGTF (Sponsored by MGFnTFBITZ) 9 20-12-2009 22:28
Changing Water Pump bravot350 MG ZR / Rover 25, 200 & Streetwise 1 27-01-2009 17:07
Changing the water pump on a Rover 214 impulse1985m MG ZR / Rover 25, 200 & Streetwise 16 07-10-2007 16:32
Rover 200vi (R3) - Changing 1.8vvc water pump belt hutchy_belfast MG ZR / Rover 25, 200 & Streetwise 37 14-11-2006 16:19
Changing water pump Amagoza Others 2 11-10-2004 13:43
