Clutch advice needed. - MG-Rover.org Forums
post #1 of 3 (permalink) Old 06-04-2017, 08:38 Thread Starter
4 months ago I bought a 2003 Streetwise 1.4 with 55000 miles. After a month when the frosty weather arrived the problem started= start engine-push clutch to engage gear-clutch pedal goes to the floor with no resistance-panic-push clutch many times,no improvement-after about 5 minutes with engine running there was a metallic twang noise and full clutch operation resumed. Even though the frosty mornings have gone the problem still persists, until the engine has been running for some time and I assume put some heat into the block/bellhousing the clutch is very reluctant to perform. I described the symptoms to my friendly*local garage and he said it's the hydraulic cylinders (even though he knows it's cable). Can any expert point me in right direction for a remedy.Thanks
ray.webster is offline
post #2 of 3 (permalink) Old 06-04-2017, 09:26
Car: Rovers - 75's, 600 & 25
Is the clutch release arm stuck? (the arm that the cable attaches to on the gearbox)
They are known to corrode where the arm locates on the gearbox and stop moving, or move very little..
- I had this problem some time ago.. you might not be able to see it without removing the battery box though..
Kev
kbonney88 is offline
post #3 of 3 (permalink) Old 06-04-2017, 19:34
Could be release bearing seizing too. Either way I think it'll be a gearbox out job to investigate.
lsto is offline
Advice needed... clutch gone candygt 'R8' Rovers (aka Wedges!!) 3 21-06-2014 18:46
Clutch problem advice needed please Reynard MGF and MGTF (Sponsored by MGFnTFBITZ) 7 03-06-2013 09:47
Rover 75 Clutch - Advice Needed colinb444 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 19-07-2011 14:03
help advice needed for a Rover 75 clutch fingers mclean MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 09-12-2008 05:53
Advice needed from anyone who's done a clutch change DieselJack Diesel Forum! 3 26-09-2007 13:24
