Dead 2.0D 25 any ideas?? - MG-Rover.org Forums
  • 1 Post By E_T_V
post #1 of 6 (permalink) Old 15-02-2017, 19:35 Thread Starter
Car: 2.0D Impression
on the way in to work all electrics stopped working i.e no speedo/tacho or lights, indicators lcd display went off too also horn would not work either, so i pulled over turned it off on the key but it kept running (at this point temp guage went thru the roof) so i stalled it. then find out its not overheating, now it wont start not enough juice in battery. Turning the key nothing happens, the alarm starts sounding off whilst investigating (had to pull the wires out of the horn for silence) had immobiliser issues twice but that was making relay noises under the dash, this time however none of that. so i have had jump leads on & nothing also dash/ign lights are flickering when key out. checked fuses all ok checked alternator leads too all ok.
Nomad76 is offline
post #2 of 6 (permalink) Old 15-02-2017, 19:41
sounds like a possible earth fault? have you checked the main battery earth cable?
Furryroo is offline
post #3 of 6 (permalink) Old 15-02-2017, 20:07 Thread Starter
thats a No
Nomad76 is offline
post #4 of 6 (permalink) Old 20-02-2017, 21:39
As above broken earth connection most likely to slam panel or to gearbox.
Nomad76 likes this.
post #5 of 6 (permalink) Old 21-02-2017, 15:47
Car: KENTAUR Rover 25 1.4 16V 76 KW (2004)
Have you checked the battery voltage is correct?
If when you start the ignition key is not illuminated red light with the battery it is possible that not correct alternator voltage regulator.
Blueser is offline
post #6 of 6 (permalink) Old 21-02-2017, 15:57 Thread Starter
checked earths all ok battery on charge now
Nomad76 is offline
Instrument Panel Dead... any ideas? Abshak MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 17-12-2007 11:22
Dying/dead Zr Diesel - Any Ideas?? LadyV-UK MG ZR / Rover 25, 200 & Streetwise 6 17-05-2007 14:19
MG ZR 2.0 Diesel - DEAD. Any ideas?? LadyV-UK MG ZR / Rover 25, 200 & Streetwise 7 13-04-2007 17:26
Dead MGF - any ideas?? ahdguy MGF and MGTF (Sponsored by MGFnTFBITZ) 1 08-01-2005 11:28
dead 214, any ideas on the problem.... Sutmae Others 12 30-11-2003 15:45
