dealing with rust - MG-Rover.org Forums
post #1 of 7 (permalink) Old 22-06-2006, 15:55 Thread Starter
Car: rover 214 si 1996 (bubble)
dealing with rust
ive got some rust on one of my arches and some round the petrol filler cap flap.i can sand it down and treat it but im worried bout the painting afterwards,im pretty sure it will need to be blended but how would i do it myself.cheers
jay27 is offline
post #2 of 7 (permalink) Old 22-06-2006, 17:17
Car: Rover Coupe Turbo
Send a message via MSN to < KEVIN >
i would be quite lengthy to explain, i'd leave it to the experts in my opinon if you not competant.
< KEVIN > is offline
post #3 of 7 (permalink) Old 22-06-2006, 18:11
dont what ever you do leave it bare metal , get it smooth and level with primer then get proffesional help if you need to ask mate dont try becaue it takes a lot of lot of practise to get it right
Carl is offline
post #4 of 7 (permalink) Old 23-06-2006, 18:41
Touching up
Touching up using aerosols is an art, particularly if it's metallic. It takes a great deal of patience, time and practice. Try on some pieces of scrap metal or similar until you have the knack. If we don't try, we'll never learn but you don't want to ruin your pride and joy. You could always get a quote from a professional if your motor is half decent. If it's just a runabout it may be worth a go. If you do have a go, apply in thin coats, leave it a good time between coats or you will get runs (in the paint, not to the toilet), and read the safety instructions as most paints are veeerrry toxic! Don't forget to use T-cut or similar to remove the roughness and overspray.Enjoy.
Mike T is offline
post #5 of 7 (permalink) Old 23-06-2006, 21:31 Thread Starter
ill put up some pics of the rust,its not alot,prolly bout half the size of a match box on the wing and even less by the filler cap.
im worried bout getting it done professionaly as i got a feeling they will charge somthing silly like 100
jay27 is offline
post #6 of 7 (permalink) Old 24-06-2006, 06:21
Mine has rust on the rear arch under fuel cap and both front arches.
Has previsouly been treated, but the dafter bugger who did it sprayed half the car with primer, then sprayed over that with a crap orange peal finnish.
I tried to take it back to get rid of orange peal. but just exposed the primer underneath! :o/
so I had to take the whole lot back, to just the part that was sanded and filled. Now I have a thin pale mark where the primer is visible. around the rear arch on near side.
I have been for the last month or so, been working on spraying a new arch I brought on ebay.
was brand new with factory primer. After buying it I couln't afford to get it done proper.
so I decided i'd have a go. think I've sprayed about 20 layers, and taken 15 back off.
It's bloody hard to get right.
I'm at the stage where I'm happy with the finnish now. It's not perfect, but i'l settle its the best i can do! It's slightly lighter than the rest of the car though I havn't sprayed it with lacker yet though, which I'm hoping will dull it down.
Mr Flibble is offline
post #7 of 7 (permalink) Old 25-06-2006, 10:00
it would prob be over that if you took it 2 a bodyshop! mine was just under 1200 for both frontwings, bonnet and bumper blown in! and they did a crap job! ive just found a bloke though who will do the whole car for 150 plus paint so its worth looking around!
Heggie is offline
first time at dealing with rust jay27 Car Care & Detailing Forum 3 10-08-2008 17:56
best way of dealing with rust Bbroomlea MG ZR / Rover 25, 200 & Streetwise 13 28-02-2008 13:37
