did they ever do electric body coloured wing mirrors on the 200? - Page 2 - MG-Rover.org Forums
post #21 of 33 (permalink) Old 19-03-2017, 08:27 Thread Starter
teh
Car: Rover 200 (95-99)
You received what I sent to your mail account?
sorry I hadn't checked my email last night, those are exactly what I was after, I hate to be a pain but do you have one for the 200 as well? I would like to make sure what I've got in the haynes manual matches - from testing with a multimeter it would seem the switch works backwards to how I expect, eg haynes manual says left hand mirror up will make a connection between 2 pins but I have to push the switch down to see that connection made
those diagrams are excellent btw where do you get them from?
teh is offline
post #22 of 33 (permalink) Old 19-03-2017, 09:26
Check your email.
I have my sources of information which I collected throughout many years ...
post #23 of 33 (permalink) Old 19-03-2017, 09:45 Thread Starter
teh
thank you that is perfect
teh is offline
post #24 of 33 (permalink) Old 22-03-2017, 18:43 Thread Starter
teh
do you know of any pictures of the factory door wiring? I'd just like to see how the mirror cable is supposed to be routed through the door
teh is offline
post #25 of 33 (permalink) Old 22-03-2017, 19:10
Unfortunately I do not have such picture.
post #26 of 33 (permalink) Old 22-03-2017, 22:18 Thread Starter
teh
no worry, I have routed it sensibly anyway
I did not need to take the front wing off in the end, I partly undid the wheel arch lining and pulled the plastic to one side so I could get my hand in and sort out the rubber grommet
still wondering about this switch though, looking at the diagrams you gave me I'm sure the ZR one is labelled wrong, passenger left seems to be connected up to the vertical motor for example, and the way it says in the haynes manual it seems like the switch will work backwards, in my head if I push the switch left the selected mirror should move to face more left, if I push the switch up it should move to face more upwards, but putting a multimeter on the switch seems to show the exact opposite of the required connections are made
teh is offline
post #27 of 33 (permalink) Old 23-03-2017, 17:43 Thread Starter
teh
this is funny
looking around the back of the fuse box to find a couple of wires I want to hook these up to, I noticed the passenger electric window fuse only has one wire coming out of it, it's always worked though!
teh is offline
post #28 of 33 (permalink) Old 23-03-2017, 21:32
The MGF/TF wing mirrors also come electrically heated but are also tiny in size.
Stargatemunky is offline
post #29 of 33 (permalink) Old Yesterday, 07:29
Mirror switches should not be different. IIRC all switches from MGF/TF, R200/25/MG ZR are all the same.
Why you do not put everything on the table connect it all and see in live what is happening?
post #30 of 33 (permalink) Old Yesterday, 07:49 Thread Starter
teh
I don't have a 12v source in the house
but I will be wiring it into a terminal block or something first before soldering just to check, it could be the diagrams are labelled wrong, or it could be it just works opposite to how I think
how does your switch work? if you move it to the left does the mirror turn to face left etc?
teh is offline
post #31 of 33 (permalink) Old Yesterday, 07:51 Thread Starter
teh
I got a pair off ebay with my colour code for 30, they're the same size as the originals, looks really good on the car
teh is offline
post #32 of 33 (permalink) Old Yesterday, 08:09
Originally Posted by teh View Post
How does your switch work? if you move it to the left does the mirror turn to face left etc?
My switch works as expected. When moved to left mirror is facing more left etc.
I even needed to change the switch and bough some from eBay and just swaped.
Mind not to buy LandRover ones as the are little bit different.
Your source of 12V can be car battery.
post #33 of 33 (permalink) Old Yesterday, 08:35 Thread Starter
teh
the one I got was from a ZR, though it did have one manual mirror and one electric so maybe it was a retrofit and they bought the wrong switch, but I don't think it matters, I'll wire it up like in the diagram and if it's wrong I'll swap some pins around until it works
teh is offline
can anyone help electric wing mirrors and electric windows trophyblue02 MG ZR / Rover 25, 200 & Streetwise 6 25-04-2012 22:57
Can you take the coloured backing off the wing mirrors? nhowes MG ZR / Rover 25, 200 & Streetwise 2 17-07-2006 12:46
Rover 214 SEi Body Coloured Mirrors Formula1Freak 'R8' Rovers (aka Wedges!!) 13 05-04-2005 23:05
Body Coloured Mirrors ferrismrk Others 8 09-03-2003 21:36
214 Body Coloured bumpers???? 214 Si Mod'd Others 15 07-11-2002 12:24
