Engine coolent empties daily. White smoke from exhaust - MG-Rover.org Forums
post #1 of 6 (permalink) Old 28-03-2011, 22:45 Thread Starter
I have been checking the coolent level on my car every other day as i already know there seems to be a problem. I was driving today when the engine just cut out and died. When i opened up the bonet, the coolent tank was empty. I filled this back up with the emergency water bottle i carry with me in my boot and the car started again. However driving it home tonight, it died again and it's hard to see in the dark but looks like the tank is empty again. There is now alot of white smoke pumping out through the exhaust aswell.
If anyone has any ideas please help it would be greatly appreciated as im useless with cars, i really dont have a clue.
xmas01245 is offline
post #2 of 6 (permalink) Old 28-03-2011, 22:53
Temporary Seller
Car: Solar Red 120
Head gasket mate. Its dead.
Mine did this friday... stop driving it straight away!
RyanZR is offline
post #3 of 6 (permalink) Old 28-03-2011, 22:54
If you drive without coolant in the engine to the point where it stops running you may well do serious harm and there is a real danger that the head gasket will now be damaged and perhaps the cylinder head too.
Does your heater still blow hot? If not it is a good indication that there is no coolant flow and the engine should not be driven until it is sorted. This usually just means bleeding the air from the system, but there could be other reasons.
Check this thread about coolant leaks - Guide to Cooling System Leaks. Rover 200/25/400/45 + MG ZR/ZS K-series.
1955diesel is offline
post #4 of 6 (permalink) Old 28-03-2011, 23:12 Thread Starter
argh so annoying! ive had nothing but bad luck with cars. Thanks for the response. Do you have any idea how much this will cost ?
post #5 of 6 (permalink) Old 28-03-2011, 23:23
Car: R45 TD Heavily modified, wolf in sheep's clothing
Exclamation
depends on damage done and your ability to repair wild guess 400-600 depends on what you do, ie water pump, cambelt, head skim, new stretch bolts MLS gasket etc etc
Magicalwill1 is offline
post #6 of 6 (permalink) Old 28-03-2011, 23:25
Head gasket. i have the exact same thing a week ago. After shoping around cars booked in the garrage for the morning. Its costing me 300 pound
Jonorover is offline
White smoke and water blowing out the exhaust tanglfc MG ZR / Rover 25, 200 & Streetwise 3 15-01-2011 22:41
White Smoke From Exhaust bluelight27 MG ZR / Rover 25, 200 & Streetwise 18 09-04-2008 20:15
White Smoke from the Exhaust ZT_Turbo MG ZT / Rover 75 (Sponsored by Rimmer Bros) 0 17-04-2007 21:24
How to stop white smoke from exhaust ? drambuee MG ZS / Rover 45 & 400 3 22-11-2006 16:44
White smoke from exhaust jason Others 6 29-01-2003 20:44
