The Fine Art of Owning: A Rover 25 - Page 21 - MG-Rover.org Forums
 53Likes
post #401 of 419 (permalink) Old 11-03-2017, 14:01
Dorchester's Avatar
"Pressures were perfect at 28psi"
Isn't it a bit too low?
IMHO the right pressure must be around 31psi.
And I like them to be a tad over inflated to 34psi.
Dorchester is offline
post #402 of 419 (permalink) Old 11-03-2017, 14:49 Thread Starter
Nope. 28psi is correct.
In a round about way. I talked about this subject earlier in this thread. The Rover had the wrong sized tyres on all 4 wheels. Tyre vendor websites kept calling my Rover a 1.4. Not a 1.6. As a result, they kept recommending the wrong sized tyres, along with the wrong pressure.
In Summary:
1.4: 30psi. (175/65R14)
1.6: 28psi. (185/65R14)
Figures taken from the Owners Handbook. Moving swiftly along.....
The interior work on the Rover is finished. A good vacuum and a dust and polish has been done. I decided not to over do it. I've left a mark or two for the new owner to clean. Anything that has been 'overdone' looks suspicious. Well. It does to me anyway. Finally, I checked that the remaining electrics still worked. I haven't used the electric mirrors for ages. They were still in good order. So. All that remains is the outside. Monday looks like the best day for that, as the Sun will be out.
Spudgun! is offline
post #403 of 419 (permalink) Old 11-03-2017, 15:11
Dorchester's Avatar
Don't want to argue, but I have got 185/55/15 tyres & alloy wheels (before that I had got 175/65/14) and Haynes reads:
Normal driving conditions - 185/55/15 or 175/65/14: 2.1 bars / 30 psi
Speeds above 100mph (or heavy loads) - 185/55/15: 2.4 bars / 35 psi
Speeds above 100mph (or heavy loads) -175/65/14: 2.3 bars / 33 psi
In the French owner's manual, 185/65/14 doesn't exist.
But you are quite right for 185/65/14: normal 1.9 bar / 28 psi or speedy / loaded 2.1 bars / 30 psi.
post #404 of 419 (permalink) Old 11-03-2017, 16:56 Thread Starter
Yup. Everything checks out. Now you can see the difference between the 1.4 and the 1.6 Rover 25's.
The question of the difference between steel and alloy wheels is an interesting one. It's not so much of a problem for the Rover 25 as the wheel size is obvious (14" steel. 15" alloy). It certainly was a problem when I had a Rover 416. I went to get a pair of tyres changed and the Dept quoted tyres for steel wheels. I pointed out that I had alloy wheels and that I wanted the correct tyres for them. A small argument ensued. I got the tyres that I wanted (Factory specified Pirelli P6000's if I remember correctly).
It just goes to show that the lists that tyre vendors have isn't as accurate has the original handbook (or indeed a Haynes manual).
Spudgun! is offline
post #405 of 419 (permalink) Old 11-03-2017, 17:00
Correct tyre pressures are not an exact science. The ideal pressure will vary not only according to tyre size, but can also vary from one make (or model) of tyre to another.
The figures given in the owners handbook (or Haynes) will be a good average that will be suitable for most tyres of that size, but you may well find with a bit of trial and error that a couple of psi higher or lower than the handbook recommendation is more suitable.
In an ideal world, everyone would have the tyre manufacturers manual for the model of tyre fitted, which would tell you the correct pressure for that particular tyre according to the weight the car puts on it. However, tyre companies seem very reluctant to allow ordinary people to see these.
post #406 of 419 (permalink) Old 14-03-2017, 16:37 Thread Starter
Oh Lordy. What a day. I was hoping for a bright sunny day. Well. That's what the forecast said at the end of last week. So much for the weatherman.
I had scheduled the Rover the final preparations for the Ebay listing. The 25 had to be washed, waxed and polished. Then the photo's for the listing had to be taken. Things didn't go according to plan....
I took a trip to the local car wash. Although it wasn't out of order or anything. It couldn't be used. There was some work being done there by some contractors and they were using the car wash lane as a car park! I went home again to re-think my plans.
If you've seen a previous photo of the Rover and Jag parked together. You'd notice that they close together. I wanted to reverse the jag, so I could get some nice shots of the 25 from all angles. That promptly went out the window, as somebody else had parked where I wanted to put the Jag. The weather had also started to close in. Everything had started to go to pot.
An hour later, things had started to change. The other car had vanished and the weather looked a bit brighter. It was still overcast, but at least there was more light. I brought the Rover into the drive and gave it a wash. It wasn't the soapy extravaganza that I wanted, but needs are as needs must. A quick wipe down and a quicker wax later (Yeah. Not as good as I wanted), I parked the Jag in the now vacant slot and positioned the Rover ready for the Ebay photo's.
I took a whole heap of photo's. Around 40 in all. It wasn't until I ran up a draft of the Ebay listing did I realise that I could only use 12 of them. It was then an agonizing decision as to what 12 photo's I was going to use. I had to use pictures that showed the Rover at its best, but also show that it also had faults. I decided to mention the faults in the text. It was the best of a bad job really. On the whole. The photo's were OK. They would've been a lot better if it was sunny outside. The red of the body colour would've looked a lot brighter (Another best of a bad job).
Now. I think it would be protocol if I didn't say anything about the auction while the listing is live. Nor do I think that using photo's that are in the listing should be Posted here (To my mind. It's a conflict of interests thing). I'm not even going to Post a link to the auction. Suffice to say; The auction will go live on Thursday, around 7pm. However. I'm pretty sure that it's safe to Post a couple of the unused photo's. So here they are.
Roverlike and Dorchester like this.
Spudgun! is offline
post #407 of 419 (permalink) Old 14-03-2017, 16:50
Dorchester's Avatar
Nice interior you have (had). Better and brighter than the boring dark grey.
IMHO that protocol looks a bit stiff. Here no seller's banned to advertise freely on the net even an auction in on its way. Weird.
Nevertheless I'll try to find out that mysterious one.
Good luck to you.
post #408 of 419 (permalink) Old 14-03-2017, 16:58 Thread Starter
The protocol is somewhat self imposed. I'm on other Forums and advertising and linking is prohibited.
Then there's this:
Why can't I post my car for sale in here?
Spudgun! is offline
post #409 of 419 (permalink) Old 15-03-2017, 18:16 Thread Starter
It's been a looooonng day.
After the efforts of getting the Rover ready yesterday. I thought I could sit back and relax a bit. Not a chance. In an act of vengeance, it rained in the morning and then the sun decided to come out to play. WTF?????? The weather was supposed to be dull and overcast. That's why I did the photo's yesterday. After shaking my fist at anyone who might be looking from above, I set to work again.
In Summary:
T-Cut; Rubby, rubby, rubby. Polish; Rubby, rubby, rubby. Photo's; Clicky, clicky, clicky.
You know. The photo's I took yesterday are actually better than the ones I took today. The cloudy weather diffused the light so it was more even. The Rover looked a bit strange with one part brightly lit, while another part was in shadow. I'm not changing the photo's in the listing. Here's a photo that I took today.
Think I'll stay in bed next time.
Spudgun! is offline
post #410 of 419 (permalink) Old 15-03-2017, 20:09
Agreed, yesterdays pics are better! The driver's door looks faded on the latest one. btw good luck with the sale
post #411 of 419 (permalink) Old 15-03-2017, 22:55
Shame your in Devon, I think my Sister would like this car, she had a red
200 bubble, she loved it and thinks about it often.
ROVER-25X is offline
post #412 of 419 (permalink) Old 16-03-2017, 11:04 Thread Starter
Distance can be a bit of a problem when you're selling on Ebay. Not only is Devon in a cul-de-sac. The distances are quoted 'as the crow flies'. I've had to add a note at the bottom of the listing to the effect of: Cardiff may be only 35 miles away, but the Bristol Channel is in the way. You are not Jesus and Rovers don't float.
Spudgun! is offline
post #413 of 419 (permalink) Old 16-03-2017, 18:48 Thread Starter
Well folks. The Auction has begun.
There was a last minute tussle with Ebay's software. For some strange reason, it wouldn't accept that the engine size was 1.6L. It wouldn't accept 1.4L either. Considering I was using a pull-down menu for the engine size. I've no idea of what was going on. I'm not all that worried though. The engine size is clearly stated in the Lots title.
Spudgun! is offline
post #414 of 419 (permalink) Old 16-03-2017, 20:08
Dorchester's Avatar
You're definitely a master... in suspense & thrilling stories!
Can't wait!
post #415 of 419 (permalink) Old 16-03-2017, 21:24 Thread Starter
Can't wait!
Thank you. I wonder if I ought to Post some of the guff I've written in the Off Topic Section.
Spudgun! is offline
post #416 of 419 (permalink) Old 18-03-2017, 21:19
I like your advert mate.
post #417 of 419 (permalink) Old 18-03-2017, 21:38 Thread Starter
Thanks for that.
I feel it's honest. Yes. It's true that I left out a lot of stuff. Somehow, I don't think that mentioning that the front speakers were blown and that I've fitted the tweeters was relevant. The majority of people who would be interested in looking and maybe even buying, would only be interested in certain aspects that have been addressed. IE: Head gasket and other known faults. So I've geared the advert towards your average shumck who wants a cheap car.
I'd rather see it go to an enthusiast though (Who wouldn't?).
Spudgun! is offline
post #418 of 419 (permalink) Old 23-03-2017, 18:52 Thread Starter
Well. The Auction is over. It didn't sell. Over 200 views and 7 Watchers and not a single bid. I had the starting price at 345 and nothing happened. I'm not gutted. I'm not even surprised. It's well known that Rovers aren't exactly popular (With the exception of the Rover 75). So what now?
The 25 is insured until the end of April, so I've a bit of time to play with. I really want to see it go by the end of this month. I will be relisting it. The listing will go up unchanged. I might lower the price a bit, but not by much. Getting the Auction to end at this time of a 5 week month was a bit of a gamble. Most people would only have 4 weeks money to last them 5 weeks. By getting it to end almost on pay day. They'll have 5 weeks money to last them 4 weeks. I should do a bit better.
Hey ho!
Spudgun! is offline
post #419 of 419 (permalink) Old 23-03-2017, 19:26
Dorchester's Avatar
Bad luck!
For that price (but with the wheel on our right side of course!) I would bid for yours every day of the year!
Keep fingers crossed for the next time.
rover 25 2002 starts fine 2 mins then no power 5 mins more drives fine? Falcon_II MG ZR / Rover 25, 200 & Streetwise 4 12-08-2011 13:14
Celebrities Owning/Driving MG Rover smogcloud MG / Rover Related Chat - up to 2005 51 12-06-2005 21:29
A non Rover owning midlander speaks... Smartz MG / Rover Related Chat - up to 2005 9 12-04-2005 08:57
New to owning a rover newrover82 Others 2 16-10-2004 19:55
