Glowplug relay bypass - MG-Rover.org Forums
post #1 of 6 (permalink) Old 30-04-2017, 17:17 Thread Starter
Having issues with the glowplug relay. Bought one to replace a failed one and now that's gone too. Anybody know what faults may cause that? Also wondered if anyone has made a bypass with a switch and how they did it? Any ideas would be appreciated!
Bathrat is offline
post #2 of 6 (permalink) Old 01-05-2017, 21:15
How has the replacement failed?
It is worth noting that the light on the dash has no relation to when the glow plugs are turned on.
post #3 of 6 (permalink) Old 03-05-2017, 12:54 Thread Starter
It stopped working. I'm aware the light comes on anyway, as i say it's a problem that's happened before so just wondered if it's a common issue and if so has anyone set up a bypass and what did they use to do so.
Bathrat is offline
post #4 of 6 (permalink) Old 04-05-2017, 22:44
Relays do occasionally fail, but a bypass isn't going to help that as it is the power contacts that burn out.
The light on the dash still comes on even when the glow plugs are not used/needed.
I assume you are testing for voltage at the plugs when someone turns the ignition key on with a cold engine?
post #5 of 6 (permalink) Old 05-05-2017, 09:18 Thread Starter
No voltage is reaching the plugs. My garage told me to try a bypass straight to the plugs as that's what they did when they found the relay wasn't working and it fired up right away. I bought a new relay and it was all quick start until this relay went and I'm back to long cranking. I can only think something is blowing the relays out.
Bathrat is offline
post #6 of 6 (permalink) Old 05-05-2017, 20:50
Measure the resistance of the plugs (after removing the electical connector from the top). Resistance should be an ohm or 2. If zero then it is a dead short and that may be the reason you are overloading the relay. If inifinite that plug isn't working either. Replace any dead ones and see if that helps. I assume you've fitted the proper relay with the huge electrical contacts (rather than a normal auto relay).
mg zr glowplug relay/timer richtryinghard MG ZR / Rover 25, 200 & Streetwise 5 01-02-2013 20:45
MZ TR - Glowplug relay sbk1972 Diesel Forum! 4 03-04-2012 20:13
Glowplug relay under bonnet JonnyB1978 Diesel Forum! 8 18-09-2009 22:04
R75 CDT Glowplug Relay oh look its me Wanted 0 09-03-2008 11:23
Rover 115SD glowplug relay 'chatter' shigg Metro / Rover 100 14 11-01-2003 07:17
