heater blower motor - MG-Rover.org Forums
post #1 of 2 (permalink) Old 01-05-2012, 19:05 Thread Starter
Unhappy heater blower motor
having trouble with the blower motor on my 25 1.4,it works for a few minutes on all speeds the just seems to get slower and slower and then it stops,if i leave for a few hours/overnight it does the same,ive checked the fuses inside and out and swapped the relays to check and all fine,could it be a dodgy motor? if so can it be swapped out with out removing the facia?
fastfred1 is offline
post #2 of 2 (permalink) Old 01-05-2012, 19:11
If blower does this on all speeds, including 4th then motor should be the one to look. If it does not do it on 4th speed maybe worth to check blower resistor pack.
IIRC motor is behined glove box compartment, so you need to remove glove box to be able to reach it.
Dam Heater blower motor? Gaffirth Diesel Forum! 6 08-03-2012 21:23
Removing heater blower motor - how?! richw MG ZR / Rover 25, 200 & Streetwise 4 28-02-2012 14:08
Heater/blower Motor help lydo33 MG ZS / Rover 45 & 400 6 15-01-2012 19:21
Removing Heater Blower Motor propwash MG ZR / Rover 25, 200 & Streetwise 2 06-02-2011 21:17
Heater blower motor expatmanc MG ZS / Rover 45 & 400 7 18-03-2009 22:23
