HELP Losing the will to live ! - MG-Rover.org Forums
post #1 of 3 (permalink) Old 08-02-2017, 17:54 Thread Starter
SO over a month ago now My car Mg rover zr 55 plate NX55FVO keeps revving when i use the accelerator it comes up and down 2 to 3 then 3 to 4 ect. I have had so many different parts wires ect. Changed the idle air controlle vale and Throttle position sensor. Now ive been told its 10000% Mass air flow sensor. Looking online and asking Garages ive can only see a mass air flow for
2.0 Diseal cars, also been told there is such no thing on my make of car and said "The K series engine never had a Mass Air Flow Sensor fitted, it only ever had a MAP sensor which is part number 16873/LMS065. "
Has anyone got any ideas whats going on and is there a Mass air flow sensor on my car or not as the recovery man was messing with it and he told me he has an mg and its 100% that part as said above
Jamie Hackett is offline
post #2 of 3 (permalink) Old 08-02-2017, 18:02
Moved to proper section on the forum... you should get better attention here.
post #3 of 3 (permalink) Old 09-02-2017, 06:27
What engine do you have?
No 200/25/zr petrol had a maf sensor fitted
Diesel 200/25/zr's did (but the maf on the 200 can be safely unplugged/ignored as it doesn't majorly affect the fuelling.
What are the symptoms?
If the throttle is actually sticking open and you have a plastic throttle body that isn't unknown and a new/second hand throttle body can cure it
If it is a leaking inlet manifold gasket - again not unknown (but more usually known for leaking coolant) and will cause similar problems
I assume you've tried a throttle reset?
-turn igntion on - do not start the engine
- fully press and release the throttle pedal 5 times within 5 seconds
- you may hear a chattering noise from the engine - wait till it stops
- start engine and allow idle to stabilise
- complete
Indicators. Losing will to live. Any ideas 884andy MG ZS / Rover 45 & 400 3 25-01-2016 20:26
Losing coolant, losing oil. No milkshake, no mayo. chris1987 MG ZR / Rover 25, 200 & Streetwise 4 01-12-2011 19:07
Do like my Rover but losing the will to live with this 'whooshing' noise..... Misssantosha MG ZR / Rover 25, 200 & Streetwise 7 01-05-2010 05:20
Coolant system wont bleed - losing the will to live!! dean84 Metro / Rover 100 2 06-11-2008 18:08
416i.... losing the will to live now billyboggins MG ZS / Rover 45 & 400 15 21-06-2007 23:54
