HELP!! MOT fail low&high idle speed! - MG-Rover.org Forums
post #1 of 6 (permalink) Old 03-10-2008, 17:02 Thread Starter
just MOT'd my wee rover 200vi today and was shocked to find it had failed on emissions, namely low idle speed and high idle speed. the mechanic says its almost certainly the CAT but the exhaust system is barely 5 months old!
anyone else had a similar problem or can anyone tell me what , if anything apart from the CAT it may be? any similar experiences?
any help or info massively appreciated.
franekglowacki@ is offline
post #2 of 6 (permalink) Old 03-10-2008, 19:19
check all the vaccum hoses for splits
squeakmillward is offline
post #3 of 6 (permalink) Old 03-10-2008, 19:33
Send a message via MSN to SammyP
Give it a right good thrashing before you arrive, then tell them to test emmisions first. Cats on K series cars need to be red hot to work properly.
SammyP is offline
post #4 of 6 (permalink) Old 04-10-2008, 15:54
Car: NOW HAVE A 25, 45 & 75
Hi,had same problem on a 2001 25 1.4, ended up changing the whole exhaust system including the cat, changed the lamba sensors and also changed the fueland air filter. could have gone further by changing spark plugs and leads as these can also give a mis reading.
I turn the hot air off going into the car when they goformot tomake sure allthe heat is in the engine making the cat workcorectly
LORDPSK is offline
post #5 of 6 (permalink) Old 04-10-2008, 16:12
Car: Rover 214 Si
Change the oil, Add some oil treatment and give it a good thrash before going to the MOT test and drive straight to the test and ask for the emissions to be done first whilst the car is running and the exhaust is hot so as not to waste time.
It's more likely, I think, That the lambda is a bigger suspected culprit than the cat.
However there are many reasons for poor emissions and sometimes they can be hard to find.
Tony White is offline
post #6 of 6 (permalink) Old 12-10-2008, 18:29 Thread Starter
previous post
big thx to all who responded. it was indeed the oxygen sensor. replaced and serviced now all is good again.
MOT fail - High CO...HELP!!!!! grinderofteeth Coupe 2 09-05-2008 19:58
High idle speed robbie73w MGF and MGTF (Sponsored by MGFnTFBITZ) 10 23-07-2007 11:10
Will a high ideling throttle fail an mot jbomb MGF and MGTF (Sponsored by MGFnTFBITZ) 11 18-03-2007 21:03
Idle speed too high - engine speed increasing Pete75club MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 07-01-2007 19:20
Rover 416 Mot fail high co & hc poorpeet Others 12 10-12-2004 15:55
