HGF again? - MG-Rover.org Forums
 3Likes
  • 1 Post By dert
  • 1 Post By Dorchester
  • 1 Post By gnu
post #1 of 6 (permalink) Old 11-04-2017, 21:27 Thread Starter
Car: MGF + ZR
Unhappy HGF again?
had the gasket changed along with the belts + pump ect just after Christmas.
but its been using a small amount of water, topped it up about a month or so ago and noticed today its down to the min mark
no mayo under the cap but the oil looks very dark?
super_cds is offline
post #2 of 6 (permalink) Old 11-04-2017, 21:29
Hehe...oil will always look dark if a few months old, its when it looks like coffee you have to worry....could be you had some trapped air in system which has worked its way out, I wouldn't worry that much, just top up and keep a check
super_cds likes this.
dert is online now
post #3 of 6 (permalink) Old 11-04-2017, 22:10 Thread Starter
Car: MGF + ZR
just so use to my F the water hasn't moved since iv owned it
this zr is just bad
thanks
post #4 of 6 (permalink) Old 12-04-2017, 06:55
Dorchester's Avatar
Do you see any white smoke from the exhaust?
In that case I may guess an IMG failing.
EDIT: Not that bad @super_cds! They are brilliant with a bit of TLC.
Dorchester is offline
post #5 of 6 (permalink) Old 13-04-2017, 19:13
They can take time to settle down after a refill. How much coolant is it actually using? If you can't spot a leak and it's a manageable amount, say an inch every month, I'd carry on monitoring for a while. A new coolant cap is an obvious place to start if it doesn't seem to be holding its pressure well.
post #6 of 6 (permalink) Old 13-04-2017, 19:50 Thread Starter
Car: MGF + ZR
its used the amout between max to min marks
thanks
TF 160 HGF After 2 weeks of first HGF SS5064 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 19-09-2012 14:03
Confused... HGF or not HGF? Hugh Jaleak Diesel Forum! 12 16-10-2011 19:32
HGF or not HGF? That is the question... adamelphick MGF and MGTF (Sponsored by MGFnTFBITZ) 15 21-06-2008 15:12
400 miles after HGF repair another HGF Kelem MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 05-05-2007 07:02
