How to clean gunk from coolant pipes/tank/rad? (R25/HGF) - MG-Rover.org Forums
post #1 of 24 (permalink) Old 14-05-2008, 12:12 Thread Starter
Send a message via MSN to replete
Question How to clean gunk from coolant pipes/tank/rad? (R25/HGF)
This is related to my R25 HGF progress thread.
Now that I have my header tank and coolant pipes off, how do I get all the oily gunk out of them? It's hard to get the oil out. Also, what about the radiator? I suspect that's full of rubbish too!
Thanks,
Phil
replete is offline
post #2 of 24 (permalink) Old 14-05-2008, 12:18
flush with water as best as possible (open hose set low in the expansion tank)
otherwise run with some forte cleaner in.
empsburna is offline
post #3 of 24 (permalink) Old 15-05-2008, 09:28 Thread Starter
What's forte cleaner? I don't wanna use something that might weaken the materials or anything.
Thanks for replying.
replete is offline
post #4 of 24 (permalink) Old 15-05-2008, 09:38
THIS STUFF
Automatic Washing powder (biological) will work just as well. couple of scoops and run it for a few hours and drop it out and flush with water and it will be fine.
post #5 of 24 (permalink) Old 15-05-2008, 10:10
Car: MG ZR 105, Lotus Elite 501
run it how? on the car or in the washing machine? lol
wildfire213 is offline
post #6 of 24 (permalink) Old 15-05-2008, 10:31
Yes, you have to put all the engine parts in the washing machine.
1955diesel is offline
post #7 of 24 (permalink) Old 15-05-2008, 10:33
As empsburna said, you can only get it all out by running the engine past the point when the stat opens with some degreaser in the system. It is very difficult stuff to remove!
post #8 of 24 (permalink) Old 15-05-2008, 10:41
thought so. have just put mine in with some fabric softner to make them nicer for my engine.
post #9 of 24 (permalink) Old 15-05-2008, 10:46
expansion tank can be cleaned up a treat in the dishwasher appatently!
post #10 of 24 (permalink) Old 15-05-2008, 10:47
and it might take more than one flush - when mine went some years back it took three or four attempts to get it all out!
post #11 of 24 (permalink) Old 15-05-2008, 14:03 Thread Starter
Erg, bad place for sarcasm with a car newbie such as myself! I'll take the washing machine/dishwasher comments as sarcasm.
So, I need degreaser (forte recommended).
Should I either:
  • Clean the pieces while detached from the car. What's the best method?
  • After engine is rebuilt, run the engine with something in the coolant water. Should I use degreaser or washing powder, and also, what should I do in terms of how long it runs, changing coolant etc?
Thanks,
Phil
replete is offline
post #12 of 24 (permalink) Old 15-05-2008, 14:15
Car: R2h1zZle Vvf0sh1Zzle!!
dishwasher!
I unscrewed my hezder tank and left it to soak in a sink filled with fairy
MyMgCar.com is offline
post #13 of 24 (permalink) Old 15-05-2008, 15:01
Should I either:
Thanks,
Phil
Phil.
Unless you can't see through the expansion tank for grime/cloudy boiled oil mixutre) then you can leave eveything connected and let the engine run with the forte/water mixture - no need to remove anything (apart from bottom hose on the radiator to drain and flush with water)
You may need to flush it a few times - so keep an eye on it for a few weeks.
post #14 of 24 (permalink) Old 15-05-2008, 16:16
Car: 200 1.4 16v Bubble
out of curiosity, where do you put the washing powder? In the expansion tank?
cheers
badger666 is offline
post #15 of 24 (permalink) Old 15-05-2008, 16:31
i work at a garage and we use daz, just mix it with water and put in system, run the engine, then drain. if you want to make sure none left in system flush with just clean water. it works a treat
javis9689 is offline
post #16 of 24 (permalink) Old 15-05-2008, 17:16
couple of scoops in the expansion tank should do it.
post #17 of 24 (permalink) Old 15-05-2008, 20:19
Location: Soham, Cambs (shame that people have heard of soham for bad reasons)
i dont know how good this is for your engine but i have been told that concentrated mortar cleaner, aka brick acid works well,but you need to take the bottom hose off and let the water go first, but you must only put about 250ml in, and mix it with water first, or the mix will be too strong.
danthebangerboy is offline
post #18 of 24 (permalink) Old 15-05-2008, 20:33
That sounds potentially lethal to metal parts! I'd stick with a degreaser/detergent.
post #19 of 24 (permalink) Old 16-05-2008, 10:38 Thread Starter
Originally Posted by empsburna View Post
Phil.
empsburna,
The tank was absolutely packed with gunk, it's everywhere. Couldn't see through it. There's also a thin layer of reddish substance dried onto the bottom of it as well.
I've put a bit of fairy in there, and i'll soak it again in a tub.
I'll do the washing powder thing when the engine's running.
Thanks, guys.
replete is offline
post #20 of 24 (permalink) Old 16-05-2008, 11:02
whip it out and pour some boiling water and washing powder & bleach in - you might want to chuck a handful of garden pebbles/pea gravel in and give it a good shake while you are at it.
Coolant leak - rad or coolant pipes dressur MGF and MGTF (Sponsored by MGFnTFBITZ) 17 15-10-2008 17:13
Signs of oil in coolant tank HGF? stuartm1 MG ZR / Rover 25, 200 & Streetwise 20 07-09-2008 21:51
Gunk In Coolant Tank - HGF Donners MG ZR / Rover 25, 200 & Streetwise 12 08-04-2008 11:21
white gunk in my coolant tank TF160SA MGF and MGTF (Sponsored by MGFnTFBITZ) 20 28-07-2005 16:20
Gunk in Rad dex211 Others 4 09-10-2004 12:38
