How to disconnect rear wiper? - MG-Rover.org Forums
post #1 of 11 (permalink) Old 22-12-2011, 19:36 Thread Starter
I have finally got round to buying a bike rack for my Rover 25 but on fitting it I came across a problem.
One of the struts sits on the rear Windows so I cannot use the rear windscreen wiper. My problem is this sometimes my rear wiper starts despite the fact that it is not turned on (something to do with the reverse gear).
My solution is to split the electrics to the rear wiper and put a switch in between so I can turn it on or off depending on whether my bike rack is on the car. The trouble is I cannot work out which wires to cut, can anyone help?
Thanks,
alamb200
alamb200 is offline
post #2 of 11 (permalink) Old 22-12-2011, 19:39
Car: -
Thumbs up
As the rear wiper has it's own fuse then that is the place to look.
BLMC is offline
post #3 of 11 (permalink) Old 22-12-2011, 20:29
or fit an inline fuse/switch in the hatch wiring next to the actual motor,
but pulling the main fuse is still the best easiest option
charlie74 is offline
post #4 of 11 (permalink) Old 22-12-2011, 20:39
Car: -
No need to do that mate, if it's an early car with the regular spade fuses you can use spade connectors in the fuse holder and extend out with wire and use a switch in the wiring.
BLMC is offline
post #5 of 11 (permalink) Old 23-12-2011, 12:15 Thread Starter
My plan was to mount the switch in the boot through the rear wiper cover.
Is this going to be too difficult?
alamb200 is offline
post #6 of 11 (permalink) Old 23-12-2011, 12:24
nope,, but i would recommend a cap covered switch,, that way if your carrying anything in the boot, it cant turn it off )))... might save a bit of frustration
post #7 of 11 (permalink) Old 23-12-2011, 12:36
Mmmm....Rover..
technozen's Avatar
Fix the faulty tailgate wiring loom.
technozen is offline
post #8 of 11 (permalink) Old 23-12-2011, 12:36
Car: MGTF115 & Rover25 1.4
Why not take the wiper arm off when you use the carrier? One nut.
david.c is offline
post #9 of 11 (permalink) Old 24-12-2011, 09:22 Thread Starter
I have tried removing the arm in the past and it is firmly stuck in place and will not shift.
I do not think the wiring loom is faulty I think it is by design if you are in engage reverse with your wipers turned on.
Does anyone know which of the four wires I should cut?
alamb200 is offline
post #10 of 11 (permalink) Old 24-12-2011, 13:22
Car: -
Don't cut any of the wires, do it the way I told you.
BLMC is offline
post #11 of 11 (permalink) Old 31-12-2011, 16:41 Thread Starter
No worries I will follow your advice on this.
Can you let me have any instructions on how to get at the fuse connectors so I can make the changes?
Cheers,
alamb200
alamb200 is offline
disconnect rear doors from cdl Popeye 89 MG ZR / Rover 25, 200 & Streetwise 0 19-10-2011 16:54
rover 25 rear wiper motor and wiper arm djalien10 For Sale 5 14-09-2009 20:06
HELP - Sunroof, Rear heater and Rear Wiper not working Vantango MG ZR / Rover 25, 200 & Streetwise 3 23-03-2009 16:54
Rover 414Si - 1996 - Rear wiper,rear fog problems!! markus250 MG ZS / Rover 45 & 400 8 16-11-2006 20:37
No sterio, rear wiper, rear window heater & indash alarm light! 216sli 'R8' Rovers (aka Wedges!!) 0 09-09-2006 08:45
