How much to fix a head gasket ? - MG-Rover.org Forums
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
post #1 of 22 (permalink) Old 10-02-2008, 13:29 Thread Starter
Hi
can anyone give me an idea of how much it will cost me for a garage to fix my car. Just checked my coolant and its brown and my oil is thick and nasty so im guessing my head gasket has gone. Im a bit on the skint side at the mo so want an idea of how much it might cost?
grrr is offline
post #2 of 22 (permalink) Old 10-02-2008, 13:32
Car: R2h1zZle Vvf0sh1Zzle!!
Ideally 200 - 400 dependant on garage, labour charges etc
MyMgCar.com is offline
post #3 of 22 (permalink) Old 10-02-2008, 13:33
Car: 59 plate Ford Fiesta
Yeah, as said, be happy with 300 - 350.. any more and their ripping you off. Under that, make sure they do a good job.
And someone correct me if i'm wrong but replace water pump and other things too..
Rover_214_16V is offline
post #4 of 22 (permalink) Old 10-02-2008, 13:34
Labour ought to be around the 200-250 mark, maybe a touch more. Parts ( Gaskets, Timing belt, water pump, tensioner ) around the 100 mark.
On top of that you might have to fork out for, for example, a new radiator as something will have gone ( often the water pump ) in order to cause the HGF.
Katier is offline
post #5 of 22 (permalink) Old 10-02-2008, 13:34
Originally Posted by Liam Olf View Post
300 - 400 from an independent, 500 - 700 from a dealer.
If you handy with a spanner and have a weekend free you could try doing it yourself, there are a few threads about, trying looking in the How To section and think of the knowledge you'll gain.
There's one that goes into some detail on themgzr.co.uk.
And have alot of patience
post #6 of 22 (permalink) Old 10-02-2008, 17:19 Thread Starter
Thanks for the replies, will have a look at how hard it is, if it looks scary or too hard ill have to hope i find somewhere good to do it for me
grrr is offline
post #7 of 22 (permalink) Old 10-02-2008, 17:34
Ste
Car: Audi A4 Black Edition
For water pump and timing belt to be changed as well as the headgasket id budget anywhere between 400-500, and thats at an independent garage, but your right the water pump and timing belt should be changed at the same time.
Not necessarily head gaskets can just fail due to the original gaskets being cheap and poorly designed, id investigate further to see if there is a reason, but i wouldnt start replacing things unless i knew for definate
Ste is offline
post #8 of 22 (permalink) Old 10-02-2008, 17:37
Ste
Originally Posted by grrr View Post
Hi
If you have a good sense of mechanics, have a go at doing it yourself, it really isn't that hard to do, and best of all, a HELL of a lot cheaper.
Ste is offline
post #9 of 22 (permalink) Old 10-02-2008, 20:18
also be prepared in the worst case for pressure test / skim and a vacuum test
richiepearce is offline
post #10 of 22 (permalink) Old 10-02-2008, 20:26
Car: zs 180, shogun 2.5
strip, pressure test, skim, all new gaskets, timing belt, water pump, oil, filter, rebuild, system flush, new coolant, around 450, get it to s wales and i'll do it for you... anything else like rad, rear metal pipe etc extra, but this is very rare...
probey is offline
post #11 of 22 (permalink) Old 11-02-2008, 08:45
Car: 200vi
Get in touch with JasonEbay. He did my HG yesterday and he's a mobile Rover tech (11 years). He'll come to you. Nice bloke, competitive price. Replaces everything! He's done loads of HG's for people on the forum.
dcj78 is offline
post #12 of 22 (permalink) Old 01-02-2009, 16:03
How can I contact Jasonebay
venesta is offline
post #13 of 22 (permalink) Old 01-02-2009, 16:39
juet finished doing hg on my rover 25 not a hard job but time consuming probably take a good day parts cost about 100 for head gasket, timing belt, tensioner if required, spark plugs, oil, filters, coolant
hope this helps best of luck mate
wee ted 25 is offline
post #14 of 22 (permalink) Old 20-05-2009, 16:29
h
is the any difference between a rover 214 cyliinder head and a mgzr cylinder head 1.4
davidr66523 is offline
post #15 of 22 (permalink) Old 20-05-2009, 16:40
Car: 420 TD Exec
It depends if the 214 is an 8v or 16v
The MG ZR has a 16v head, the same as the 16v 200s.
The head gasket itself is the same for all of them, though.
Olly650 is offline
post #16 of 22 (permalink) Old 20-05-2009, 22:23
early k series 16 valve heads ( up to approx 98 my) had different tensioner / belt and lower pulleys.
probey is offline
post #17 of 22 (permalink) Old 08-05-2010, 16:09
Anyone know how to contact Jasonebay or recommend someone who does this also?
I require a HG changed for my MG ZR 1.8.
Any help would be appreciated
Thanks,
Sanchez
Sanchez is offline
post #18 of 22 (permalink) Old 08-05-2010, 16:37
The price also depends on what parts are used, mine will be on the expensive side as i'm using the PAYEN MLS Kit and Bolts with a GATES Timing Belt Kit !!!
ROVER-25X is offline
post #19 of 22 (permalink) Old 08-05-2010, 16:46
Whats on the expensive side then?
Sanchez is offline
post #20 of 22 (permalink) Old 08-05-2010, 17:25
Gates Timing Belt Kit and Tensioner for a VVC (Both Belts) cost me 55 inc VAT !!!
any mechanics to fix Head Gasket? denee MG ZR / Rover 25, 200 & Streetwise 6 05-08-2008 20:20
head gasket... to fix or say good bye Meadie Metro / Rover 100 9 17-06-2008 20:38
Have NAC promised to fix the head gasket issue once and for all? Sunbeam Man MG / Rover Related Chat - up to 2005 6 05-06-2007 10:22
Head gasket has gone ! How much to fix ? 220ttblue Diesel Forum! 4 06-02-2007 15:10
Head Gasket gone..? Easy fix? or big job? 220turbo_phil MG ZR / Rover 25, 200 & Streetwise 15 26-01-2007 16:37
