mg zr central locking problem - please help! - MG-Rover.org Forums
post #1 of 16 (permalink) Old 27-07-2011, 15:10 Thread Starter
Hi, all a bit new to this, just joined the forum today.
Seen lots of good stuff here in the past so hoping someone can help.
I've got an MGZR 2004 - problem is the central locking isn't working properly. It opens off the remote fine, but will not lock of the remote. to lock it I have to push down the pass side door knob then get out and lock the drivers door from the key (which arms the alarm ok) then lock the boot.
Would really appreciate any help or advice
cheers all
cogsys is offline
post #2 of 16 (permalink) Old 27-07-2011, 15:20
Car: 160
cheers all
Check the rear tailgate loom first, open the tail gate, right side and you will see a rubber boot thing the loom breaks and chaffs in there...
Perks68
perks68 is offline
post #3 of 16 (permalink) Old 27-07-2011, 15:33 Thread Starter
cheers Perks, talk about a fast response - nice one. i'll have a look later.
cogsys is offline
post #4 of 16 (permalink) Old 27-07-2011, 15:54
Car: Ford Focus ST3
Send a message via MSN to Keefo
Yeah the Boot loom can be a ***** and cause all kinds of problems like this!
Just take off the rubber boot on the top right of the boot lid when open, check for broken/worn wires and just tidy them up/repair
also make sure your FOB isnt abit gunky or have a broken button!
Can you hear the button itself actually click?
Keefo is offline
post #5 of 16 (permalink) Old 30-07-2011, 09:49 Thread Starter
Hi, ive had a look at the tailgate loom as suggested this morning, all seems ok, no bare or broken wires, so its back to the drawing board for me. Can anyone offer any more suggestions - cheers
cogsys is offline
post #6 of 16 (permalink) Old 30-07-2011, 10:01
T4 Diagnostics
lovel's Avatar
Car: R40, R41, P6, CB40, FL2, Imp, R56, Street Twin
If you have the Oval shaped fob then you may have an issue with the BCU relay and/or driver.
Member Technozen has posted a how to on the subject.
Pektron SCU/BCU
lovel is offline
post #7 of 16 (permalink) Old 30-07-2011, 13:08 Thread Starter
Unhappy
thanks lovel,
I've followed that link, sure it's useful but it's all a bit beyond me i'm afraid. I couldn't even locate the EBU/SCU let alone change relays - D'oh !! would be interested to know where it is though ?? if there's no other possible (simplier -LOL) things I can check then I guess i'm goona have to live with it.
At the risk of sounding like a complete muppet, i was lookin in my trusty haines manual and cannot see the EBU in the wiring diagram for central locking. confused !!
cogsys is offline
post #8 of 16 (permalink) Old 31-07-2011, 17:09
Car: 2014 MG3 Style Lux and 2000 Rover Mini Cooper Sportspack
Send a message via MSN to MGR_Petrolhead
thanks lovel,
The BCU is a small box located behind the glovebox on later 25/ZRs. If your car does not have air conditioning, it will be easier to get at.
MGR_Petrolhead is offline
post #9 of 16 (permalink) Old 31-07-2011, 18:25
Car: 160
Buddy, don't dismiss by it looks ok...Did you pull off back the rubber boot, exposing the wire loom inside the boot..Don't just check the front and back side of the boot-use a bit of fairy in it and slide it back..
Perks68
perks68 is offline
post #10 of 16 (permalink) Old 01-08-2011, 17:00 Thread Starter
Cheers perks, I did have a good look at the exposed wires mate. A few chaffing marks but no broken or bare wires. I think - as suggested by others - the problem lies within the central locking relay in the bcu/scu. Followed a link posted by someone above, helpful but i'm worried about doing more harm than good. I never used a soldering iron before, if I could get a relacement relay, would need some guideance their. I guess to get the old relay off the board I just use some heat from the iron? Who knows! Would also need/appreciate any tips on soldering the new relay to the board. Gonna have a think whether to tackle this job, would like it sorted though cos othe than this my zr in top nick 04 plate only just over 20k on the clock had it since new
cogsys is offline
post #11 of 16 (permalink) Old 01-08-2011, 18:06
Car: ZR TD 115+
Before doing all that I would take the door card off to have a look inside, could be a mechanical fault. When I did mine there was stuff like chewing gum plastered all over the metal rod that the pin is attached too.
This made it really sticky and the motor was unable to move the pin as there was bit of foam the rod was sticking too, confused the hell out of the central locking!
Plastering a load of grease in there wouldnt hurt too, the above might not be the cause, its only a guess though.
Lovewise is offline
post #12 of 16 (permalink) Old 01-08-2011, 18:42
T4 Diagnostics
lovel's Avatar
You could possibly remove the BCU and send to Technozen for checking or repair?
lovel is offline
post #13 of 16 (permalink) Old 01-08-2011, 21:09 Thread Starter
tThanks lovewise - already had a nose behind the drivers door card and things seemed ok. Guess I should maybe check pass side though.
lovel - that might be a good option to contact technozen. As im new to this forum. Is there a way I can contact/message him direct?
cogsys is offline
post #14 of 16 (permalink) Old 01-08-2011, 21:58
T4 Diagnostics
lovel's Avatar
Just PM him (private message) and if he is around he should get back to you.
Either in your User CP on top left or Private Messages which is highlighted on the top right adjacent to your user name.
lovel is offline
post #15 of 16 (permalink) Old 01-08-2011, 22:34
Mmmm....Rover..
technozen's Avatar
It sounds like one side of the central locking relay within the SCU has failed.
I can supply replacement relays to fix this problem (discounted for .org Supporters) or can replace the relay(s) for you if you want to send me the SCU.
PM me or send an email.... technozen@ntlworld.com
technozen is offline
post #16 of 16 (permalink) Old 20-05-2013, 12:42
Hiya guys just registered
Bought the missus a 2004 zr recently and all was fine until yesterday when the remote central locking stopped working, similar problems to the guy above except with the wifes car when you press the fob im getting a clicking noise coming from the boot, il check the loom tonight, is there anything else this clicking noise could be coming from
Scoobystira is offline
mg zr central locking problem - help !! cogsys MG ZR / Rover 25, 200 & Streetwise 2 29-07-2011 20:06
mg zr central locking problem hibee zr MG ZR / Rover 25, 200 & Streetwise 5 09-12-2010 15:45
Central locking problem on 2003 MG ZR 105+ zanhar25 MG ZR / Rover 25, 200 & Streetwise 4 12-10-2009 15:24
MG ZR Central Locking Problem. Jim2402 MG ZR / Rover 25, 200 & Streetwise 12 10-01-2007 22:05
MG ZR - Problem With Central Locking tommyg2688 MG ZR / Rover 25, 200 & Streetwise 4 22-01-2006 19:47
