MG ZR TD: brake disc minimum thickness - MG-Rover.org Forums
post #1 of 7 (permalink) Old 20-03-2017, 18:02 Thread Starter
Hi all,
Anyone knows what the minimum thickness is for the standard front brake discs for an MG ZR td + 2005 ?
I cannot find it on the net..
Thanks.
lacher is offline
post #2 of 7 (permalink) Old 20-03-2017, 19:55
vented or solid discs?
vented are 21mm new
Solid are 13mm new
post #3 of 7 (permalink) Old 20-03-2017, 20:02
First site I've checked (EBC) list 19mm and 11mm as min thickness respectively.
post #4 of 7 (permalink) Old 20-03-2017, 23:15
Isn't that the minimum thickness after being machined rather than the minimum permitted operating thickness? (not that I have actually come across a garage machining the discs level when fitting new pads during my car ownership).
post #5 of 7 (permalink) Old 20-03-2017, 23:26
That is minimum operating thickness. It is usually stamped on the edge of new discs too (not that you can read it on an old disc of course!)
post #6 of 7 (permalink) Old 22-03-2017, 00:18
Having now checked, you're quite right - I had got 18mm in my head for some reason, which is what prompted my previous post.
post #7 of 7 (permalink) Old 22-03-2017, 18:53 Thread Starter
Thanks a lot for the answers. I will try and check the remaining thickness because I have the feeling they are worn.. Will check probably this weekend.
lacher is offline
Front brake disc thickness LeRich 'R8' Rovers (aka Wedges!!) 6 02-10-2012 19:15
Brake Disc Minimum Thicknesses Captpants MGF and MGTF (Sponsored by MGFnTFBITZ) 2 20-09-2009 16:33
Minimum Brake disc thickness! CEJM MG ZR / Rover 25, 200 & Streetwise 3 25-02-2008 19:49
Minimum Brake disc thickness myjess MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 05-10-2006 15:32
Brake Disc Minimum Thickness 218is 362 MG ZR / Rover 25, 200 & Streetwise 2 24-06-2005 12:01
