Minimum Brake disc thickness! - MG-Rover.org Forums
post #1 of 4 (permalink) Old 25-02-2008, 15:44 Thread Starter
Hello everybody,
On behalf of a friend I would like to post the following question.
Can anybody tell me what the minimum thickness of the front brake discs is on a Rover 216 (1998)?
This should be in a haynes manual but due to him just having moved house he can't find the manual. The discs and pads look worn but before spending money on things that are not required I would like to know at what thickness the discs need to be replaced.
Thanks for your answers,
CEJM
CEJM is offline
post #2 of 4 (permalink) Old 25-02-2008, 16:21
Car: 214Si 16v '97 ; 2003 Peugeot 807 2.2HDi Exec
Send a message via Skype™ to 214 no 1
The way i always look at it is if there is a groove on the disks then it is overdue either replacement or skimming. Every time i have got a new car, the first thing i do is change the pads and disks so then i know they are new and where i stand with them.
My advice to your friend is that just to change them as they are easy to do and cheap so well worth it in the end. Running the disks down to the minimum thickness is not always the best option.
Welcome to the forum by the way
214 no 1 is offline
post #3 of 4 (permalink) Old 25-02-2008, 16:31 Thread Starter
Thanks 214 no 1,
The reason that he prefers not to change the discs is because he just bought another car and is in the process of selling the Rover. But it's MOT is due next month and of course it still needs to paas this. So if the discs are not worn to the minimum thickness than in this case we will leave them on the car.
Regards, CEJM
CEJM is offline
post #4 of 4 (permalink) Old 25-02-2008, 19:49
Take the car to somewhere like Nationwide Autocentres that does a free brake check. That way you can get it checked out and have them replaced (yourself, not at Nationwide ) before MOT-ing it
imroberts is offline
vvc Minimum head thickness iparkes MG / Rover Related Chat - up to 2005 6 04-11-2008 21:04
new brake disc VW Camper MGF and MGTF (Sponsored by MGFnTFBITZ) 8 21-02-2008 15:35
Minimum Brake disc thickness myjess MG ZT / Rover 75 (Sponsored by Rimmer Bros) 6 05-10-2006 15:32
R220 262mm brake disc query - Strange cut on lip of 1 disc. G13SJC 'R8' Rovers (aka Wedges!!) 21 11-03-2006 21:19
Brake Disc Minimum Thickness 218is 362 MG ZR / Rover 25, 200 & Streetwise 2 24-06-2005 12:01
