Is my car a "K Series"? - MG-Rover.org Forums
 3Likes
  • 1 Post By Chris T
  • 1 Post By david.c
  • 1 Post By LeRich
post #1 of 14 (permalink) Old 10-01-2017, 13:26 Thread Starter
Car: Rover 25 IL, 1.6V, 5 Door Hatch, 2001, Manual, Petrol, 1396cc, 62000-miles.
I'm quite new to the forum and new to being a used Rover 25 owner.
I've got quite a bit of servicing to do to it and am amazed at the information available here, to help a near numpty like myself save some money but also derive a huge amount of satisfaction from learning and doing what I thought I'd never do (service and repair my own automobile), now I'm semi-retired.
However, I see a lot of references on the forum to "K Series" motors (which I suspect mine is, but am unsure).
The vehicle details I have are as follows and I'd really appreciate it if someone could offer me some advice in order to help make sure I'm reading up on the right sections for my newly-beloved, beautiful, British Built ton of motoring majesty:
Make: Rover
Reg Date: 2001
CC: 1396
CO2e: 164 g/km
Fuel: Petrol
Vehicle Type: M1
Wheelplan: 2 Axle Rigid Body
Doors: 5 (hatchback)
Transmission: Manual
Log Book description: Rover 25 IL 16V
That's about it, unless I need to post the Engine/Chassis #'s.
Should I post a picture, or is the above sufficient info?
Thanks in advance for any advice.
Bunny
BunnyGee is offline
post #2 of 14 (permalink) Old 10-01-2017, 13:29
A petrol Rover 25 will have a K-series engine as it was the only petrol engine fitted to that car albeit in deferent displacements.
BunnyGee likes this.
post #3 of 14 (permalink) Old 10-01-2017, 13:36 Thread Starter
Blinkin' flip, that was quick. Thank you.
By "displacements" do you mean the components might be in different locations (coolant top-up at the front &/or to the left, rather than at the back and to the right, for instance) even within the same "K" engine type range, or am I misunderstanding, please?
Ooops. Please forget the above query as I think I found the answer HERE
Thanks again, tho.
BunnyGee is offline
post #4 of 14 (permalink) Old 10-01-2017, 14:40
Car: MGTF115 & Rover25 1.4
Displacement = engine size.
david.c is offline
post #5 of 14 (permalink) Old 10-01-2017, 17:16
gots me a pair o' MGs
LeRich's Avatar
Car: MG TF 135, MG ZS+ 120
The K-series came in a variety of capacities/displacements and was the only petrol engine ever fitted to the Rover 25 / MG ZR out of the factory.
In the Rover 25, the K-Series was available as a 1.1 16v, 1.4 16v, 1.6 16v, 1.8 16v and the 1.8 VVC 16v flavours. All the engines bar the VVC are basically the same with a few key differences. The VVC has a more elaborate valve control system to increase power output.
Servicing items such as filters and spark plugs will be common across all non-VVC versions.
LeRich is offline
post #6 of 14 (permalink) Old 10-01-2017, 17:39 Thread Starter
Thanks to everyone for confirming what I suspected (and hoped, given the amount of information available here for it) that my motor is, indeed, K-Series.
Now I can browse the forum with more confidence that the information either applies to me, or not, in each instance.
Nice 1
BunnyGee is offline
post #7 of 14 (permalink) Old 10-01-2017, 19:08
LeRich's Avatar
A bit more in-depth knowledge, so you're aware. The earlier 200 also used the same K-series engines, but in an earlier form that had various differences mostly centred around the ECU and ignition systems. The 200 was also available with 8-valve versions of the 1.1 and 1.4 (no 1.1 16v in the 200) which are more different still.
LeRich is offline
post #8 of 14 (permalink) Old 11-01-2017, 12:55
I don't think so
like12 is offline
post #9 of 14 (permalink) Old 11-01-2017, 18:17
LeRich's Avatar
Originally Posted by like12 View Post
I don't think so
Please explain.
LeRich is offline
post #10 of 14 (permalink) Old 15-01-2017, 09:14
Originally Posted by LeRich View Post
Please explain.
Reasonable original summary from LeRich imo
post #11 of 14 (permalink) Old 15-01-2017, 09:40
The 1400 cc 16V ist a K Engine. The best way to learn is look on Ebay or where else for a MG Rover Service CD named Rave. thats the best way to get all information.
best regards from Germany
Lee
verget the Brexit Rover Driver are United.
Rover35 is offline
post #12 of 14 (permalink) Old 15-01-2017, 11:34
Originally Posted by Rover35 View Post
The 1400 cc 16V ist a K Engine...
Mine is - deffo
post #13 of 14 (permalink) Old 15-01-2017, 15:02
Originally Posted by gnu View Post
Mine is - deffo
I think it's a typo and should read "16V is a".....
post #14 of 14 (permalink) Old 15-01-2017, 15:58
Is it is, or is it isn't?
"Demon car" "Possessed" "Evil"... dressur MGF and MGTF (Sponsored by MGFnTFBITZ) 20 22-05-2011 13:59
"J87 VOG" 420 GSi Sport "M Series" pablo3 'R8' Rovers (aka Wedges!!) 5 20-01-2011 19:06
Mating a S2000 gearbox to a K-Series, more a "How?" than a "How to!" Santilargo Other Manufacturer models 9 11-06-2007 12:34
Car "Series" identification Snaggles MG ZS / Rover 45 & 400 1 21-09-2006 18:20
"The Engineer" - latest issue has article on a "New" Rover car Windy MG / Rover Related Chat - up to 2005 1 09-05-2006 11:41
