Need an earth point - MG-Rover.org Forums
post #1 of 11 (permalink) Old 15-10-2012, 14:41 Thread Starter
Need an earth point
Got my amp today and started wiring it up. Want it under my passenger seat but need an earth point around that area. The earth lead that came with the wiring kit I've got is about 2/3 foot
tommyd007 is offline
post #2 of 11 (permalink) Old 15-10-2012, 14:44
Car: Solar red ZR 160 named Jessie, Rover Metro Pickup Truck
I would Use one of the bolts that hold the seat to the floor
betsytherover is offline
post #3 of 11 (permalink) Old 15-10-2012, 14:46
As said above mate use one of the bolts that hold the seat in place mate
Sent from my iPhone using Tapatalk
rdy416 is offline
post #4 of 11 (permalink) Old 15-10-2012, 14:48
That would be an ideal earthing point.
OP the whole of the vehicle body is an earth. The "earthing points" that MGR used were to make production easier for them and no other reason.
Just make sure there is an eyelet connector on the cable big enough for the bolt to go through and you're good
cjmillsnun is offline
post #5 of 11 (permalink) Old 15-10-2012, 15:47 Thread Starter
Bolt is too big for the terminal
post #6 of 11 (permalink) Old 15-10-2012, 15:50
Either crimp on one that is big enough, or get a washer thats slightly larger, strip a bit of the wire and solder it to the washer. Voila. Giant ring connector
Failing that, get a self tapping metal screw and screw it into the chassis somewhere (be careful where you put it though)
post #7 of 11 (permalink) Old 15-10-2012, 16:12
a lot of messing around that lol
zr crazy is offline
post #8 of 11 (permalink) Old 15-10-2012, 16:20
Yeah i know, there just options if you dont have a bigger eyelet
post #9 of 11 (permalink) Old 15-10-2012, 16:33
Car: Mk2 MG ZR 120
Could always take the seat out and cut and small hole in the carpet and run it to under the centre console?
Oliaaaaam is offline
post #10 of 11 (permalink) Old 15-10-2012, 17:44 Thread Starter
Just drilled a hole in the floor under the seat lol
post #11 of 11 (permalink) Old 16-10-2012, 08:17
Car: MG ZR PTP R140 + Alfa Giulietta Veloce 170 (220)
Too late now I know but I have got both my amps under the front seats. I used the bolts that locate the centre console at the read. There is an oblong panle just forward of the handbrake handle and under here is a decent sized bolt that can be used. Only problem with drilling and using self tapping screws is that by breaking the seal of the paint and galvanizing that you are now allowing a point for rust to start especially with dissimilar metals as steel and brass/copper of the ring terminal which can cause corrosion to start even faster due to galvanic action.
dR0Og is offline
Where is the earth point? SilverRover007 MG ZR / Rover 25, 200 & Streetwise 3 18-04-2012 20:03
Best Earth Point? coleman758 MGF and MGTF (Sponsored by MGFnTFBITZ) 15 29-10-2010 17:12
electrics earth point mrbishi75 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 08-11-2009 10:59
Earth point under seat? AliB MG ZR / Rover 25, 200 & Streetwise 8 16-05-2008 23:47
Earth Point on Mk3 200 rsymes97 MG ZR / Rover 25, 200 & Streetwise 1 04-06-2004 19:17
