New clutch, reset or replace cable? - MG-Rover.org Forums
post #1 of 7 (permalink) Old 18-05-2017, 14:49 Thread Starter
I will be fitting a new clutch kit to the 25 (R65 box) along with driveshaft seals and input shaft seal this weekend and would like to know is it strictly necessary to replace the clutch cable or reset it ?
I have read that there is a chance it can be reset and then re-adjusted to the new clutch, can anyone confirm and provide a method of doing this ?
Any tips on dropping the box on the driveway and changing the clutch and input shaft seal would be appreciated also
Thank you
MGtom91 is offline
post #2 of 7 (permalink) Old 19-05-2017, 14:52
I have never changed a clutch on one with a 65 box so I can't give any advice regarding resetting the cable.
If I was you I would buy a new one anyway from a motor factors then at least if you can't reset it you have it, if you do manage to reset it then yet can take it back for a refund.
As for the gearbox I would make sure you have an extra pair of hands you can call upon just in case.
Get some oil because if your like me you will always end up spilling some.
Good luck.
lsto is offline
post #3 of 7 (permalink) Old 19-05-2017, 15:33 Thread Starter
I have read many issues with fitting an aftermarket cable and people have had to shim them to get correct bite point etc and I dont fancy paying rimmers 40 odd quid for one. Not in a rush to get car back on the road so may do clutch and take it from there.
Bought 2L gearbox oil to go back in and also input shaft seal. Not sure if it is this or rear crankshaft seal that needs replacing though without pulling box off. There is always a drip of oil sat under bell housing and sump is also misted with oil but the drip never actually drops off the car and if wiped will just re-appear. No clutch slippage yet just juddering on first take off and very very high bite.
MGtom91 is offline
post #4 of 7 (permalink) Old 19-05-2017, 21:53
Car: MGTF115 & Rover25 1.4
Clutch cable is self adjusting.
david.c is offline
post #5 of 7 (permalink) Old 19-05-2017, 23:13 Thread Starter
I know... Aftermarket don't seem to adjust properly or enough from what other people have posted. I wanted to know really if the mechanism can be reset on the cable currently fitted.
MGtom91 is offline
post #6 of 7 (permalink) Old 20-05-2017, 11:17
When I did a g/b and clutch the old cable fitted back and self adjusted fine. Unless it's damaged, I wouldn't bother replacing it...
Rover 214 Gearbox & Clutch Replacement - Picture Diary - MG-Rover.org Forums
post #7 of 7 (permalink) Old 22-05-2017, 08:56 Thread Starter
OK then I'll refit cable. Went to have a look at your link but isn't working?
MGtom91 is offline
Wanted zr clutch release bearings and clutch cable Jamielong Wanted 2 12-04-2016 11:41
Replaced my stretched clutch cable today, now getting ridiculous Clutch Slip. gazzring MG ZR / Rover 25, 200 & Streetwise 5 01-02-2014 05:38
Where to replace speaker cable? BenSRG In-Car Audio, Entertainment, Sat Nav etc... 9 16-02-2012 17:36
Where can i buy a new clutch cable? My clutch is slipping, clutch been replaced lovemeroverido MG ZS / Rover 45 & 400 3 08-02-2007 07:15
CLUTCH CABLE/CLUTCH SLIP on ROVER 214 SLI 16v 89-95 shape lovemeroverido MG ZR / Rover 25, 200 & Streetwise 1 07-02-2007 18:14
