NLA parts - MG-Rover.org Forums
post #1 of 6 (permalink) Old 04-05-2017, 17:48 Thread Starter
NLA parts
I'm after an engine mount for my 160. The part no is KKH000201.
Does anyone know anywhere this is still available anywhere. Tried rimmer bros and dmgrs. Looked on the bay but no luck.
Any help will be appreciated.
Cheers all
lsto is offline
post #2 of 6 (permalink) Old 04-05-2017, 17:58
I do not know if they got it or not, but you can try to call them and check: Genuine MG Rover KKH000201 ROD ASSEMBLY LOWER TIE shipped from the UK to anywhere
On the other hand you need to be patient and get new on eBay when it shows up.
post #3 of 6 (permalink) Old 04-05-2017, 20:05
The Xpart finder (Welcome to mgroverpartfinder.co.uk) show nil stock.
The link is to Endon Services who often avertise stuff they don`t have in stock, relying on buying in from Xpart. I suspect that is the case here.
deebee is offline
post #4 of 6 (permalink) Old 05-05-2017, 07:13
You will most likely be better off poly bushing it. Will be cheaper and easier to find, you'll find it better afterwards as well.
https://www.powerflex.co.uk/road-ser.../ZR-220/1.html
Use the part numbers on the link above and search ebay and such like.
the chauffer is offline
post #5 of 6 (permalink) Old 05-05-2017, 08:43
Depends why he wants to replace it - is the bush degraded, or is the mount itself broken - a number of owners have had the metal part of the lower mounts break in the past.
Re. Endon Services - as with Rimmer Bros, they list everything that is on the XPart epc, but in the case of Endon, they don't flag when the epc shows it as NLA. You can check the part number on www.mgroverpartfinder.co.uk: if Endon have any in stock, it should show up on partfinder as being in stock with them, or will show as available to order from XPart if there is stock at XPart at Hinckley. If partfinder doesn't show any stock, you can assume there are none (and your only chance is to drop across an ex MG Rover/XPart retailer whose stock is no longer on the XPart system, but may still have one on their shelf.
post #6 of 6 (permalink) Old 06-05-2017, 20:34 Thread Starter
Ended up buying poly bushes in the end. Couldn't find anywhere who had them. The mount itself is fine, just the bush was shagged. I managed to find a genuine top mount on the bay but only second hand bottom ones, but I would rather new so poly bush it is. Cheers all.
lsto is offline
Shocks/Springs NLA for a 05 MGZT-T 1.8T. Alternatives? Skatiechik MG ZT / Rover 75 (Sponsored by Rimmer Bros) 9 07-06-2013 13:05
MGF remanufacturing project for NLA parts verofan MGF and MGTF (Sponsored by MGFnTFBITZ) 21 11-07-2012 22:55
ZT260 Clutch Master and Slave NLA DMGRS MG ZT V8 and Rover 75 V8 5 28-05-2012 20:57
NEW! Rover 600 Aerial Motor XUN100010 NLA X10Rich For Sale 1 14-11-2011 19:18
Rover 800 Scuttle Panels! Now NLA! Rover V6 Coupe Rover 800 28 13-11-2009 13:03
