Overheating issue :( - MG-Rover.org Forums
post #1 of 5 (permalink) Old 08-05-2013, 16:24 Thread Starter
I've read many of the threads about how to test different parts of the cooling system but I'm stumped!!
I've removed the ECU lead from engine temp sensor, which should get the rad fan working, but nothing happens. I've increased the 15 amp blade fuse in the box to 20 amps and this makes no difference.
The problem is that the engine is overheating in slow traffic and when under load when not travelling quickly (up steep hills - I live in Wales!)
What's the next thing to test? The fan itself? If so then how can I test it? Maybe the lead going to the fan? Again, how can I test it?
Any help would be great as I love the car and would hate to pop it
David
Penrhyn Plodder is offline
post #2 of 5 (permalink) Old 08-05-2013, 16:29
Car: 2005 Jaguar S-Type R, 2016 Jeep Renegade Limited, 2003 Rover Streetwise SE
It's possible the fan is dead, does it keep blowing fuses?
t0m4ever is offline
post #3 of 5 (permalink) Old 08-05-2013, 16:39
Car: Mg Zr Replica
David
never tested the radiator fan before but copy and paste from another thread
"un plug the sensor that you can see on the metal part of the water system....bottom right hand side of the engine....ones on the bottom thats for the temp dial....the other one sticking out horizontaly is the fan...when un plugged the fan should run continuously!!
its where the water comes out of the block into the hose and to the top of the radiator... "
if this dont work why not get another from the scrappy i picked up a almost brand new rad complete with fan and all the pipe work for 10
13Jaffy13 is offline
post #4 of 5 (permalink) Old 08-05-2013, 17:20
Car: MG ZR 120+
I'm afraid I can't offer any more advice than others have said on the main issue.
However I can advise you never to replace blown fuses with higher values. the fuses are all at different values for a reason, increasing that limit could cause serious electrical damage by allowing more current through than is intended, its just not a sensible thing to do.
Put it this way. Would you still use a hair dryer that had just blown a fuse but been hardwired to bypass it? I didnt think so!
Richardw1992 is offline
post #5 of 5 (permalink) Old 08-05-2013, 17:21
Car: mk2 MgZS 1of57, MG ZR+ No.2029, MG ZR 105 ,Rover 200VI Rep:■■■■■■
I have a radiator for sale along with many other parts
pm me if neede
SR4SLH is offline
MGF overheating water issue TheMadScientist MGF and MGTF (Sponsored by MGFnTFBITZ) 8 11-04-2010 19:16
Weird overheating issue Jop Diesel Forum! 10 23-11-2009 17:39
Overheating issue....Any Ideas dpfun2007 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 22-08-2009 12:23
Overheating Issue boothy72 MG ZS / Rover 45 & 400 3 18-06-2009 16:28
Rover Coupe overheating issue jtownson 'R8' Rovers (aka Wedges!!) 6 03-03-2006 22:31
