Overheating issue - MG-Rover.org Forums
post #1 of 4 (permalink) Old 02-02-2014, 10:38 Thread Starter
Overheating issue
Hey
So I am having a wyrd problem with my MG ZR, its a 1.4 petrol model, 04 plate.
The car starts to overheat after being driven for a while.
It starts fine and runs fine, idles consistently without any wyrd sounding changes in noise. There is no 'mayonaise' on the oil cap, the dipstick just has clean oil on it and there is not oil that I can see in the coolant or on the coolant cap.
I thought it may just be an airlock or something so decided to check that. So I removed the coolant cap, and removed the metal bleed screw (literally fully removed the screw). At this point the expansion tank is full but nothing is coming out of the bleed screw hole and the level of water in the tank remains the same. What does this indicate?
If I squeeze the upper and lower radiator tubes then water goes in/out of the expansion tank but I have not seen any water at all coming out of the bleed screw hole.
Any advice would be much appreciated
jaythompson is offline
post #2 of 4 (permalink) Old 02-02-2014, 15:43
Car: 1989 R0ver 213.
poke a little screwdriver or something similar in the hole, I have known the hole to be blocked under the bleed screw.
jensden51 is offline
post #3 of 4 (permalink) Old 02-02-2014, 16:45
Car: Year 2000 Rover 216 SLi "Bubble shape"
I second the above - found it completely blocked twice now, once when we first got the car years ago (that was a confusing), then again a couple of months ago (no surprise the second time)...
paul_spencer is offline
post #4 of 4 (permalink) Old 02-02-2014, 17:27
Thanks guys, will give it a go.
Don't know why I did not think to try that myself!
JayT is offline
MGF overheating issue smcg2020 MGF and MGTF (Sponsored by MGFnTFBITZ) 4 15-05-2013 12:18
Overheating issue :( Penrhyn Plodder MG ZR / Rover 25, 200 & Streetwise 4 08-05-2013 17:21
Weird overheating issue Jop Diesel Forum! 10 23-11-2009 17:39
Overheating issue....Any Ideas dpfun2007 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 22-08-2009 12:23
Overheating Issue boothy72 MG ZS / Rover 45 & 400 3 18-06-2009 16:28
