Painting my front grill - MG-Rover.org Forums
post #1 of 6 (permalink) Old 09-03-2017, 18:54 Thread Starter
Hey guys, as I was painting my front grill I tried to remove the front bumper but the bolts on one of the wheel arches were kinda messed up and to make thing better I ended up trashing them, and my question is, is there any way to remove those bolts? So I can get new ones and be able to remove the front bumper for other ocasions. I'll leave the video if you guys are interested in the painting process.
Stoyan Stoev is offline
post #2 of 6 (permalink) Old 09-03-2017, 19:32
cut them out and use a new bolt and washer
MissYasmine is offline
post #3 of 6 (permalink) Old 09-03-2017, 20:31 Thread Starter
By saying cut them out are you refering to the fender liner or the bolts?
post #4 of 6 (permalink) Old 09-03-2017, 20:34
The bolts that hold the front bumper to the wings are captivated in one of two brackets - they often get rusted up (especially the one nearest the wheelarch) and they twist off when you try to undo the nut. One bracket holds the bolts that attach the bumper to the wing, the other bracket holds the wing to the inner wing.
You can either make a new bracket yourself, drill holes in the right places and use ordinary bolts, or you can replace the bracket with a new one. Both brackets are still available to order from any MG Rover/XPart agent:
Outer wing to inner wing - http://www.rimmerbros.co.uk/Item--i-ASU470030
Bumper to wing - http://www.rimmerbros.co.uk/Item--i-DPP100960
post #5 of 6 (permalink) Old 10-03-2017, 01:13
Car: (Mgf sold)Zr 120
Outer wing to inner wing - Bracket assembly-fender support - Genuine MG Rover at www.rimmerbros.co.uk
Bumper to wing - Plate-front bumper stud - Genuine MG Rover at www.rimmerbros.co.uk
I can vouch for this. I swapped the bumper on my girlfriends zr the other week and the bumper to wing bracket pretty much turned to dust at the sight of a ratchet so make sure to have a new one ready before you do it. We needed the car roadworthy the next day so I ended up having to drive to rimmers at lincoln for it.
Davemgfzr is offline
post #6 of 6 (permalink) Old 10-03-2017, 21:56 Thread Starter
Thanks for the reply, I will probably end up trying to fix it by myself I will try to drill the holes in the right places with the ordinary bolts.
BRM front grill listed as a 200 grill on ebay gunner9662 Rover 200 BRM 1 11-06-2009 14:53
painting grill dazz150 Others 7 29-03-2006 06:29
Rover25, painting front grill and meshing Dave MG ZR / Rover 25, 200 & Streetwise 2 06-05-2005 23:02
painting chrome grill on bubble 200 geeza10328 MG/R Modification & Tuning 5 25-04-2004 22:46
Painting a front splitter Broon MGF and MGTF (Sponsored by MGFnTFBITZ) 9 06-10-2003 15:34
