Poor performance - MG-Rover.org Forums
post #1 of 16 (permalink) Old 11-09-2009, 19:18 Thread Starter
Car: 25 Track Car in Prog...
Poor performance
Been out for a drive and the car felt worse than usual. It was'nt responsive and didnt accelerate as well as it has before. Could it be something like plugs? leads? it had a service not long back which was changed oil filter new oil and think a new fuel filter.
Any help would be great
Tom
Tom163 is offline
post #2 of 16 (permalink) Old 11-09-2009, 19:25
Car: Astravan 165
Was it ok after the cambelt/water pump change?
HotTubRepairer is offline
post #3 of 16 (permalink) Old 11-09-2009, 19:30 Thread Starter
Yeah fine, litterally just this last drive. I have been all over today and this last trip about 20 miles it was'nt right someware.
Tom163 is offline
post #4 of 16 (permalink) Old 11-09-2009, 19:34
did u do the service or was it a garage because i belive that u change the plugs at the same time as the fule filter ie 60k
cooper1200 is offline
post #5 of 16 (permalink) Old 11-09-2009, 19:42 Thread Starter
It was a garage and it was only a annual service 40K. They wer'nt on the recipt either.
Tom163 is offline
post #6 of 16 (permalink) Old 11-09-2009, 19:53
Car: MAZDA BONGO!
Check leads, if it's still lumpy take it back.
Si
eddiesolo is offline
post #7 of 16 (permalink) Old 11-09-2009, 20:39
the plugs r easy to get to... just take the cover and the coils off with an 8 mm socket and the plugs are a 10mm spark plug socket. Make sure you pull the tubes off the plugs carefully cos sometimes they r stuck slightly a little wd40 works a treat. If the plugs are whiteish it indicates a weak air/petrol mix where as black indicates a rich mix. If the plug electrodes r oily that indicates a more serious prob.
its a simple job just dont over tight anything when u come to put it back and remember which lead/coil goes where.
Hope this helps
Coop
post #8 of 16 (permalink) Old 12-09-2009, 13:17 Thread Starter
Si
Take it back were? lol
Hope this helps
Coop
Yeah, I did this a while back and they were fine but will have another look I suppose.
Cheers.
Tom163 is offline
post #9 of 16 (permalink) Old 12-09-2009, 16:52
Car: ZS 120+ MkII
Si
The garage that done the service maybe?
Matt
matt77303 is offline
post #10 of 16 (permalink) Old 12-09-2009, 17:46 Thread Starter
Si
Matt
No point really mate as nothing they did could really affect the performance. Will just change the plugs to better ones, maybe the leads and all the other rubbish.
Tom163 is offline
post #11 of 16 (permalink) Old 12-09-2009, 17:50
Car: Impreza Turbo, Focus diesel Estate, Rover 25 1.4.
Have you checked the cam timing since the running issues began? it's not impossible the cam timing has slipped which would result in poor running/power/economy. It's free, so worth checking
SnapdragonGT is offline
post #12 of 16 (permalink) Old 12-09-2009, 17:54 Thread Starter
Had a check mate both timing marks are symetrical.
Tom163 is offline
post #13 of 16 (permalink) Old 12-09-2009, 18:50
Ahh bugger, fair play for having a gander though!
Like suggested then, possibly a HT issue, also check all the sensor plugs and wiring are in good clean, dry condition.
Hope it gets resolved, I hate mystery running maladies!
post #14 of 16 (permalink) Old 12-09-2009, 19:12 Thread Starter
Hahaha cheers mate
Tom163 is offline
post #15 of 16 (permalink) Old 12-09-2009, 22:46
Car: mk5 astra xp pack
oil and coolant clear?
slickman is offline
post #16 of 16 (permalink) Old 13-09-2009, 11:11 Thread Starter
Yep no HGF signs still.
Tom163 is offline
418 Poor performance mn757 'R8' Rovers (aka Wedges!!) 4 02-06-2007 15:27
Poor performance Mister Ron MGF and MGTF (Sponsored by MGFnTFBITZ) 2 30-05-2007 19:10
noisey and poor performance johncramanderso Diesel Forum! 8 13-08-2006 21:34
hot weather,poor performance jay27 MG ZR / Rover 25, 200 & Streetwise 17 11-06-2006 23:26
Turbo + Poor air quality = Poor performance? selwonk MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 01-07-2005 18:43
