Random chafing noise after cam belt change - MG-Rover.org Forums
  • 1 Post By **Kayleigh**
post #1 of 7 (permalink) Old 10-01-2017, 22:22 Thread Starter
Hi All,
Odd problem after a cam belt, water pump and tensioner change.
Every so often, after seemingly random intervals, the car starts and it sounds like the cam belt is rubbing on the plastic housing. Turn the ignition off and start it again and the noise is gone. It can stay silent for weeks and then off it goes again. Switch off and on again it it sounds fine.
The car is smooth, engine sounds dead smooth despite having 101k on it and it pulls fine.
Has anyone had this before? The tensioner was definitely set up and torqued correctly.
Cheers,
Jools
Joolspb is offline
post #2 of 7 (permalink) Old 10-01-2017, 22:29
Banned
If it was me id be back tracking and looking for evidence of rubbing.Not doing could get expensive.
JT Dent is offline
post #3 of 7 (permalink) Old 10-01-2017, 23:03 Thread Starter
I plan to as soon as I can get a day of light without it peeing down It's the intermittent nature that's puzzling as I can imagine what could happen between one start and another that would cause it.
Joolspb is offline
post #4 of 7 (permalink) Old 12-01-2017, 14:53
Car: MK1 ZR 105, and MK2 ZR 105
probably engine vibration when starting or even switching off
you can easily take the top half of the cover off and run the engine without, to rule that part out.
otherwise its under the arch, with a light and check the lower cover, you might struggle for access through with the alternator and ps belts on.
161racer is offline
post #5 of 7 (permalink) Old 12-01-2017, 20:25
As above just check it to be safe. My car was meant to have a new belt just before I bought it 7 months ago, and yesterday on my way to work it snapped.
Now I have a headache, expense and inconvenience for my troubles...
Check it before you end up stuck on the side of the road like I was.
Good luck.
lsto is offline
post #6 of 7 (permalink) Old 13-01-2017, 08:30
MG-Rover Mobile Mechanics
**Kayleigh**'s Avatar
Car: MGF, MGTF, MGZS x6, MGZR x6, MGZT x1, ROVER 25, ROVER 216 Cabriolet, 93' CELICA
Send a message via MSN to **Kayleigh**
Possibly a broken cambelt cover or it's too tight x
gnu likes this.
** We specialize in Mg / Rover Head Gaskets, Servicing, Maintenance & Repairs **
-- Our Head Gaskets are 320 non vvc and 350 vvc --
... All Head Gasket Replacements are inclusive of the Cambelt & Waterpump ...
~ We can guarantee you won't find anyone offering the services we do, at the prices we do! ~
' Vehicle collection and return is also available for work needing to be transported to our unit '
* See www.mg-rovermobilemechanics.com or call/text 07595708278/07595704340 for more info *
**Kayleigh** is offline
post #7 of 7 (permalink) Old 28-01-2017, 12:25 Thread Starter
Hi All,
Sorry for the delay getting back, life's been a bit hectic recently.
Interestingly, I kept using it for short trips to see if I could get it to happen again and have a go at tracing the source but so far, it hasn't reoccured. I leant it to a visiting relative for a week and he put a lot of miles on it with no problems.
Looks like I'll just wait for a dry weekend and give it a good going over.
Thanks for all the suggestions and help. Will update if I find anything in case someone else has the same problem.
Cheers,
Jools
Joolspb is offline
Cam Belt Noise Ruby Murray MG ZS / Rover 45 & 400 5 23-12-2014 21:14
Engine light on after cam belt/FIP belt change. Leigh_EvoIX Diesel Forum! 17 07-12-2012 23:12
V6 cam belt noise jerrythemole MG ZT / Rover 75 (Sponsored by Rimmer Bros) 3 15-09-2011 22:33
MGF VVC weird noise after cam belt change...HELP! fuzzyHGF MGF and MGTF (Sponsored by MGFnTFBITZ) 8 07-04-2003 20:45
MGF Ticking noise after cam belt change...HELP! fuzzyHGF MGF and MGTF (Sponsored by MGFnTFBITZ) 8 07-04-2003 12:49
