Rear Silencer - MG-Rover.org Forums
post #1 of 8 (permalink) Old 23-06-2007, 16:12 Thread Starter
Rear Silencer
My rear silencer has gone, got a price for the parts to do it myself, just wondering what kind of figure I'd be looking at if I took it to an exhaust place?
imroberts is offline
post #2 of 8 (permalink) Old 23-06-2007, 18:01
Car: Rover 25 1.6 Club
When I changed my rear silencer on my R25 I paid around 80 with fitting included.
Check around for prices, because I don't it can be that much more expensive in the UK.
Chris87 is offline
post #3 of 8 (permalink) Old 23-06-2007, 18:03
Tws
Car: '98 214 SE
I'd definitely do it yourself. Mine went last year, got quotes around the 100+ mark (just to replace the back box) from rip off merchants Kwik Fit. Some local garages were around 50, which is quite reasonable. Did it myself for just the price of a back box - 31. The only problem was having to saw through the rusted bolts - that took a while!
Tws is offline
post #4 of 8 (permalink) Old 23-06-2007, 18:12
Car: Astravan 165
I usually pay around 30-40 fitted. Shop around and watch out for the expensive large companies, especially the one mentioned above.
HotTubRepairer is offline
post #5 of 8 (permalink) Old 24-06-2007, 13:50
Car: Discovery 300 V8 & TD5, MR2 Turbo.
where bouts you from am in lincolnshire have a nearly new standard jobbie you could have for a tenner vvery to fit jack up car undo the two bolts they may be very tight slide the new one in not sure if i have the gasket but il have a look if any one wants it
loudandproud205 is offline
post #6 of 8 (permalink) Old 24-06-2007, 13:54
Car: MGZT pbt derv
The bolts will undo easier when the exhaust is hot, also put some penetrating oil around the bolts/threads as well.
Should be dead easy.
Skelo
Dave is offline
post #7 of 8 (permalink) Old 24-06-2007, 18:14 Thread Starter
Will I need exhaust paste or is it not needed with gasket type exhausts?
post #8 of 8 (permalink) Old 24-06-2007, 18:29
Car: MGZT pbt derv
Just use the existing gaskets, should be ok.
Skelo
Dave is offline
New Rear Silencer puddingandpie MG ZR / Rover 25, 200 & Streetwise 2 06-07-2008 11:36
Rear Silencer box design xr3tf MGF and MGTF (Sponsored by MGFnTFBITZ) 17 26-02-2008 04:32
Rear silencer Oyster45 'R8' Rovers (aka Wedges!!) 2 05-07-2007 00:14
X Power rear silencer chiesa Diesel Forum! 3 19-04-2007 23:37
REmoving Rear silencer ajamesj Others 3 04-09-2002 23:17
