rear windscreen washer not working - MG-Rover.org Forums
post #1 of 9 (permalink) Old 25-04-2007, 08:58 Thread Starter
a minor annoyance on my "to-do" list
the front windscreen wash works fine but when i try to do the back all i can hear is the pump, no water comes out. i reckon theres a trap somewhere :P
any advice?
shocka144 is offline
post #2 of 9 (permalink) Old 25-04-2007, 09:11
remove the boot trim to expose the washer motor,
more than likely your tubing to the motor has popped out, also put a pin down the jet nozzle to see if there is anything blocking it.
coopsman1 is offline
post #3 of 9 (permalink) Old 25-04-2007, 09:15
On my R25 i find that the one way valve behind the boot trim keeps blocking! Its managed to block itself again at the mo, i just spray it with some WD40 to loosen any dirt but am thinking i might remove it all together!
Stu
stu1982 is offline
post #4 of 9 (permalink) Old 25-04-2007, 09:22
Car: Pug 307 :(
Send a message via MSN to mattshaw
No need to go to this effort straight away..... first, pull back the black plastic sleeves between the top of the boot lid & the roof. This is where all the wiring (RHS on a R200) & water pipes (LHS R200) go. More often than not, the constant opening & closing of your boot has weaken the tube that runs through this section & cracked it. Simply repair this & youll be back on your way
(if this doesnt work, then go for the method mention by coopsman1, very similar but more uncommon )
mattshaw is offline
post #5 of 9 (permalink) Old 25-04-2007, 11:25 Thread Starter
cheers guys, what does the boot lid look like and how do i go about removing it?
as u can see i know nothing bout cars :P
post #6 of 9 (permalink) Old 25-04-2007, 19:54
Car: 214Si 16v '97 ; 2003 Peugeot 807 2.2HDi Exec
Send a message via Skype™ to 214 no 1
The "Boot Lid" is the door you pull up to gain access to the "Boot" , where your spare wheel etc lives. With this lifted up you will see two, black, rubber tubes going from the car body into the boot lid. The one on the left next to the hinge is the one that has the washer pipe in it.
HTH
214 no 1 is offline
post #7 of 9 (permalink) Old 26-04-2007, 10:05
Car: Mg ZR 120
I had the blockage problem recently on my ZR, it turns out the screenwash had caused the problem, it must have gone off or something and clogged up the pipes. It seems to have gradually freed itself up, but now my rear jets need lining up as i tried the pin treatment first off, they either don't spray far enough up the screen or past it, i just can't seem to get them right...
egglington is offline
post #8 of 9 (permalink) Old 26-04-2007, 10:08
Car: TT MGF #0002
How do you line them up? Mine are out at the moment as well. Do you just stick a pin in them and move them like that?
gotenks1321 is offline
post #9 of 9 (permalink) Old 26-04-2007, 16:26 Thread Starter
found the rubber tube was able to expose the blue pipe but it looked bone dry
Rear Washer Working Too Well?! Joe-ZR MG ZR / Rover 25, 200 & Streetwise 5 13-05-2008 01:47
Rear windscreen washer Thorpy1987 MG ZR / Rover 25, 200 & Streetwise 4 05-04-2008 23:42
Rear windscreen washer parkes1978 MG ZR / Rover 25, 200 & Streetwise 3 04-02-2007 13:58
Rover 214 rear windscreen washer alek Others 3 16-11-2005 16:24
mk3 200 rear windscreen washer not workin projectgaz MG ZR / Rover 25, 200 & Streetwise 1 01-07-2005 19:26
