Replaced my stretched clutch cable today, now getting ridiculous Clutch Slip. - MG-Rover.org Forums
post #1 of 6 (permalink) Old 31-01-2014, 12:12 Thread Starter
Car: Rover 200 BRM LE No: 793, Rover 200 BRM LE Track K Turbo.
I set about replacing my clutch cable today, the old cable had a cracked (blue) bit as was moving up and down the cable meaning it was extremely notchy to get in gear an on a couple of occasions I could not get it out of gear.
I replaced it today with one from a motorfactors.
The issue now seems to have gone the opposite way, now when depressed the gear change is lovely and smooth, the bite point is however right at the top of the peddle, and when accelerating the clutch has been slipping like nothing I've ever experienced. It would appear that it isn't being released enough?
Could my arm be seized?
The clutch & release bearing are about 15k old, I've heard they are auto adjust, is there anything I need to do to get it to adjust properly?
PG-1 Gearbox on a BRM.
gazzring is offline
post #2 of 6 (permalink) Old 31-01-2014, 12:43
Car: Rover 200 Track car 180BHP, MK2 MG ZR-T16
The cable is auto adjust and can be adjusted by pulling lever opposite direction, as for slipping clutch due to siezed arm, well you could get someone to operate it and watch the arm or when driving there will be loads of slack in the pedal and cable when it's slipping.
pengy_666 is offline
post #3 of 6 (permalink) Old 31-01-2014, 13:06 Thread Starter
What lever Pengy?
No slack at all really other than usual, as soon as you touch the clutch it starts to disengage it?
gazzring is offline
post #4 of 6 (permalink) Old 31-01-2014, 14:19
Car: Mini (The real one)
Where it comes out into the engine bay, give it a tap with a spanner and move the spring up and down. If it's still doing it, you may want to look into the adjustment height of your clutch pedal.
Steve220 is offline
post #5 of 6 (permalink) Old 31-01-2014, 21:23
Undo the cable and see if the clutch arm moves freely up and down. IF not then it may well need lubrication (or a gearbox removal to sort fully)
post #6 of 6 (permalink) Old 01-02-2014, 05:38
Car: MG ZR160
Stupid question, is the cable secured properly or caught on anything? That would create what youre experiencing.
Popeye 89 is offline
How to know if clutch cable snapped / clutch broken? CrazyFig MG ZR / Rover 25, 200 & Streetwise 12 13-02-2013 11:46
420td...Spongy Clutch Pedal + Clutch Slip. drjunk MG ZS / Rover 45 & 400 0 10-01-2009 10:57
Which has died.. clutch, gearbox or clutch cable. dynamis_dk MG ZR / Rover 25, 200 & Streetwise 22 11-02-2008 17:35
Where can i buy a new clutch cable? My clutch is slipping, clutch been replaced lovemeroverido MG ZS / Rover 45 & 400 3 08-02-2007 07:15
CLUTCH CABLE/CLUTCH SLIP on ROVER 214 SLI 16v 89-95 shape lovemeroverido MG ZR / Rover 25, 200 & Streetwise 1 07-02-2007 18:14
