Replacing a door mirror on a Rover 25 - MG-Rover.org Forums
post #1 of 4 (permalink) Old 08-04-2006, 09:04 Thread Starter
Question Replacing a door mirror on a Rover 25
I've seen instructions for removing the door panel. Do I need to do this to change a door mirror or do I just have to carefully prise off the black triangular cover in the corner?
gdalby is offline
post #2 of 4 (permalink) Old 08-04-2006, 10:00 Thread Starter
Solved!
I discovered that it's simply brute force that's required. I see that to remove the mirror I will probabbly have to remove the panel to get to the lowest torx screw.
gdalby is offline
post #3 of 4 (permalink) Old 11-04-2006, 00:30
Send a message via MSN to Sutty88
all i did on my 200 was remove the screw closest to the mirror and pull the card off a little bit then pulled the mirror thing off!
Saved loads of time
Ash
Sutty88 is offline
post #4 of 4 (permalink) Old 11-04-2006, 08:32 Thread Starter
I don't know whether the 200 is different but it seemed that the torx screws were too far down into the panel to do that. Probably was possible but after removing the door handle surround I prised off a small part of the panel and it was easy.
gdalby is offline
Rover 25 GTi N/S Door Mirror (Electric, Heated) obiwan Wanted 3 31-08-2006 19:42
Replacing Rover 25 Door Handles?? Need Help Plz... dynamis_dk MG ZR / Rover 25, 200 & Streetwise 3 14-04-2006 10:14
Crome Door/wing Mirror Covers For 25 McLaren Wanted 0 20-03-2006 02:45
Replacing a door on a Rover Metro simon.croak Metro / Rover 100 3 19-10-2005 21:18
replacing door mirror glass @ MGF Data_DK MGF and MGTF (Sponsored by MGFnTFBITZ) 0 30-06-2002 10:47
