Rover 200 (R3) - 1998 - Gearbox oil - MG-Rover.org Forums
post #1 of 7 (permalink) Old 06-11-2006, 12:23 Thread Starter
Hiya i have a 98 rover 200 and i was wondering how much gear box oil it holds and how hard is this to fill or top up?
danicalifornia is offline
post #2 of 7 (permalink) Old 06-11-2006, 12:26
Dont know and Dont know.
what do know is that the engines 1.1 to 1.6 use the R65 gearbox that uses the normal EP75/80 gearbox oil 99% on other manual gearboxes in the world use.
1.8 to 2.0 use the PG1 gearbox which uese MTF94 oil.
Cirian75 is offline
post #3 of 7 (permalink) Old 06-11-2006, 18:45
Car: Silver Stormer ZR turbo.
As long as you empty the box first you'll be safe to put 2 litres in. Usually 2 one litre bottles.
If it's an R65 which it will be if it's a 214 or a 216 the easiest way to fill is via the black breather cap on top of the box.
ashy is offline
post #4 of 7 (permalink) Old 06-11-2006, 21:50 Thread Starter
its a 220 ds is this the same type of gear box
post #5 of 7 (permalink) Old 07-11-2006, 05:50
that should be a PG1 gearbox.
the oil for that is MTF94.
Cirian75 is offline
post #6 of 7 (permalink) Old 07-11-2006, 12:44 Thread Starter
i had bought ep 80w-90 gear oil is that of no use now
post #7 of 7 (permalink) Old 07-11-2006, 12:57
on a PG1 gearbox yes, that oil can not be used in it, MTF94 oil must be used.
local motorfactor should stock it.
failing the B*W mini uses the same gearbox oil, I think, not 100% on that.
Cirian75 is offline
Just done my yearly oil change Rover 200 (R3) but..... cr4igp4lmer MG ZR / Rover 25, 200 & Streetwise 5 20-11-2006 17:05
Rover 200 (R3) - 1998 - Yellow relay npd1962 MG ZR / Rover 25, 200 & Streetwise 7 15-11-2006 06:31
Rover 200 (R3) - 1998 - Camshaft gasket dimension?? r0uter MG ZR / Rover 25, 200 & Streetwise 2 14-11-2006 13:43
Rover 200 (R3) - 1998 - Cambelt Mike L MG ZR / Rover 25, 200 & Streetwise 6 14-11-2006 09:16
Rover 200 (R3) - Tesco engine oil jay27 MG ZR / Rover 25, 200 & Streetwise 17 09-11-2006 22:41
