rover 214 starting problems - MG-Rover.org Forums
post #1 of 6 (permalink) Old 23-11-2009, 09:03 Thread Starter
Car: Rover 200 (-95)
not sure if this the right place but, got a 214 8v on an m plate. when its cold and damp it struggles to start, i aint got much of a clue under the bonnet and this morning it wouldnt start and now the battery is dead. what would you sudgest is wrong with it??? really doing my head in, cheers in advance
blower32 is offline
post #2 of 6 (permalink) Old 23-11-2009, 10:42
Car: 2004 MG ZR 120+
Erm! new battery?
misterreliable is offline
post #3 of 6 (permalink) Old 23-11-2009, 21:09 Thread Starter
Originally Posted by misterreliable View Post
Erm! new battery?
eerm, no. the battery only died cos i tried starting it to much
blower32 is offline
post #4 of 6 (permalink) Old 23-11-2009, 21:25
Car: FJ1100 STREET FIGHTER
damp equals ignition struggle.
check rotor arm* and distributor cap* for corrosive build up, that doesn't conduct electric current.
check spark plugs* for gap.
spray leads with water repellant.
if in doubt, just replace.
BIGGUNS is offline
post #5 of 6 (permalink) Old 23-11-2009, 21:37 Thread Starter
sprayed leads today, ill take distributor cap off tomorrow, cheers for help
blower32 is offline
post #6 of 6 (permalink) Old 23-11-2009, 21:47
in the cap are four metal pick-ups, they are shiny metal, but will probably have a white crusted oxide coating, this needs to be scraped off, using small screwdriver. Check the central graphite/black pick up is spring loaded, just push it gently and it should return. Also inspect the cap for cracks.
The rotor arm on its outside edge, clean up with a few rubs of fine wet and dry paper, back to shiny brass.
if this allows the car to start.............. at the earliest opportunity replace.
BIGGUNS is offline
Rover 214 R Reg - Immobiliser/starting problems!! sarahc64 MG ZR / Rover 25, 200 & Streetwise 2 20-10-2009 17:46
rover 214 p reg starting problems claire_chrissie MG ZR / Rover 25, 200 & Streetwise 5 10-03-2009 12:42
Rover 214 Si (bubble) starting problems Matt KB MG ZR / Rover 25, 200 & Streetwise 23 11-03-2006 18:38
Rover 214 starting problems again! pslaney Others 5 01-03-2006 19:14
Rover 214 Si starting problems JackieB Others 1 27-06-2002 14:16
