ROVER 25, 2.0 IDT ... MAP or EGR problem - Page 2 - MG-Rover.org Forums
 2Likes
post #21 of 36 (permalink) Old 01-12-2016, 10:36 Thread Starter
With my EGR vaccum pipe blocked, witch settings gives me more power:
1. with MAF with paperclip
2. with MAF disconnect and without paperclip?
Now iti with pipe block and paper clip on MAF but feels powerless(before needing to block EGR pipe it has more power...
alex_orastie is offline
post #22 of 36 (permalink) Old 01-12-2016, 13:02
If the ECU doesn't notice that the MAF is bypassed then you should get more power with the paperclip in the wiring connector than without it. (without it plugged in the ECU will definitely know it is faulty and ignore the signal and use default safe fuel levels which are lower at high rpm. )
I assume you are connecting the correct two pins on the MAF sensor plug (not the maf sensor itself)?
post #23 of 36 (permalink) Old 01-12-2016, 13:25 Thread Starter
yes...1 and 5 i thing i connect from MAF sensor plug...
post #24 of 36 (permalink) Old 05-12-2016, 09:43 Thread Starter
Originally Posted by E_T_V View Post
Don't bother with the rimmers site trying to find part numbers for the nozzles as I don't think they'll have them
The nozzle part numbers are:
Di injector nozzles
DSLA 145 P 446
25/45 injector nozzles are
DSLA of 145 DSLA P 870
You want to swap the P870 nozzles which you have with the P446 ones.
i have found in my garage 3 injectors.... KBAL70p46 200 ... something like that ... are they SDI or TDI? i have not find no1 electric injector...
post #25 of 36 (permalink) Old 06-12-2016, 18:59 Thread Starter
E_t_v ... Do u know????
post #26 of 36 (permalink) Old 06-12-2016, 21:01
If they have 200bar stamped on them then they are probably DI injectors which flow more fuel. You need all 4 though!
post #27 of 36 (permalink) Old 08-01-2017, 21:09
Car: 2.0D Impression
can i join in?
hi gents im interested in MORE POWER would ditching the CAT improve things? i am thinking about a straight thro bit of pipe replacement.
AND is it that simple to get hp gains as mentioned just by changing injectors?
Nomad76 is offline
post #28 of 36 (permalink) Old 08-01-2017, 23:13
Depends on what car you have to start with!
post #29 of 36 (permalink) Old 10-01-2017, 23:41
its a... Rover 25 2litre Diesel
Nomad76 is offline
post #30 of 36 (permalink) Old 10-01-2017, 23:51
Diesel Tuning Dude
Dakta's Avatar
To put it very briefly, the 'usual advice' for a 25 diesel for more horsepower would be (generic advice follows):
service > fit sdi injectors > increase boost (~19psi) > remap to suit
(+ decat if desired at any stage for slightly improved spool)
The remap and sdi injectors are where most power gains are to be had, you can do one or the other, or both but you must do at least one for more power. The decat as you mentioned wont do a right lot but will help with spool.
Other options like mafless, egr deletes etc are possible with a remap so if anything like this is necessary it sort of answers its own question.
Nomad76 likes this.
Dakta is offline
post #31 of 36 (permalink) Old 11-01-2017, 00:07
Nice one Dakta that's what i'll do then! any ideas why its slug like below 2k? (NOT egr valve fouling) but y'know that smallbore vacuum pipe that comes off egr thats held on with insulation tape & well placed zip tie cos its broke at egr end
Thoughts?
Nomad76 is offline
post #32 of 36 (permalink) Old 11-01-2017, 00:20
Diesel Tuning Dude
Dakta's Avatar
These engines will never give a massive amount of power below 2k, but the biggest cause of it to be excessively poor under 2000rpm is a failing maf sensor - this is VERY common.
Dakta is offline
post #33 of 36 (permalink) Old 11-01-2017, 01:33
yer i tried to get maf out the "tool" i bought dont fit but it needs sorting out so going down the service & injector bit first,
just need a bit more poke tbh
Nomad76 is offline
post #34 of 36 (permalink) Old 11-01-2017, 14:35
Unplugging the MAF sensor may well restore your lost low rev power (at the expense of a lower rev limit and on post -04 cars turning the engine management light on).
If it does restore performance the MAF is definitely tired.
Nomad76 likes this.
post #35 of 36 (permalink) Old 22-01-2017, 21:01
i will try that this week sometime i have a few other issues as well ie one clip on air box left i have a cable tie holding it in but i think air is getting in where i dont want it to, also vacuum pipe on egr is knackered, the egr valve is clean, i just think it should pull a damn sight better than it does
thanks
Nomad76 is offline
post #36 of 36 (permalink) Old 11-02-2017, 23:44
any idea where i can get injectors from?
Nomad76 is offline
Wobbly Gearstick Rover 25 2.0 IDT fergw MG ZR / Rover 25, 200 & Streetwise 13 03-07-2015 12:33
2004 idt egr blank graaham1808 MG ZS / Rover 45 & 400 6 07-03-2015 23:02
Big problem with my Rover 45 iDT engine vladd.alex MG ZS / Rover 45 & 400 27 17-08-2013 09:19
My Rover 45 2.0 iDT is smooking vladd.alex MG ZS / Rover 45 & 400 6 26-06-2013 14:12
rover 25, 2.0 IDT-ABS problem alex_orastie MG ZR / Rover 25, 200 & Streetwise 22 19-11-2011 07:16
