Rover 25 - tyre pressures. - MG-Rover.org Forums
post #1 of 7 (permalink) Old 31-03-2010, 11:54 Thread Starter
I have a rover 25 (X reg) my alloys have 185/55r 15 82V tyres on. What are the correct tyre pressures that I should be using?
Thanks for all of your help chaps.
rider78 is offline
post #2 of 7 (permalink) Old 31-03-2010, 12:16
Car: MGTF115 & Rover25 1.4
Manual says 30 psi all round.
david.c is offline
post #3 of 7 (permalink) Old 31-03-2010, 12:23
Car: Civic Type R
Tyre pressures should be on the tyre wall but more than likley its around the 30ish mark
Rick
Ricky is offline
post #4 of 7 (permalink) Old 31-03-2010, 12:35
Car: Rover 200 SDI Bubble
the correct tire pressure will vary from manufacturer to manufacturer
pirellis will need one, michelins will differ, budget tires again differ
have to look at the tire wall and tread depths for a good gauge
if the tire wall has a fat belly and the tread depths are lower on the outsides, increase the pressure a few psi's
IanWalton is offline
post #5 of 7 (permalink) Old 31-03-2010, 13:19
Car: Rover 25 GTI (formerly ZT190/214 bubble 200 VI)
Send a message via MSN to spampebs
32psi front because thats where the engine is!!
30psi at the back, but the manuel might tell you 32 if your going on a long journey with a full car!!
driving with low pressures for long periods will seriously shorten your tyre life!!
spampebs is offline
post #6 of 7 (permalink) Old 31-03-2010, 19:41
correct pressure is 2.2 bar which is around 32 ish psi (cant quite remember) fronts and rear btw
majesticric is offline
post #7 of 7 (permalink) Old 31-03-2010, 19:51
not far off, as said though, as the engine is over the front wheels they need slightly more pressure to prevent deformation of the tyre!!
spampebs is offline
Tyre Pressures?! steve740 Rover 600 4 19-06-2007 12:39
tyre pressures on 185/205 tyre combo? highlander69 MGF and MGTF (Sponsored by MGFnTFBITZ) 10 09-03-2007 19:15
Rover 200vi (R3) - Tyre pressures simon.guna MG ZR / Rover 25, 200 & Streetwise 7 04-11-2006 13:34
Tyre Pressures? langers_00 MGF and MGTF (Sponsored by MGFnTFBITZ) 1 01-02-2006 10:40
Tyre pressures? Ken75 MG ZS / Rover 45 & 400 5 29-11-2003 18:16
