Rover 25 vvc speedo dead - MG-Rover.org Forums
post #1 of 7 (permalink) Old 02-03-2017, 20:30 Thread Starter
My 1999 non abs rover 25 with a 160 engine is has developed a problem, the revs and speedo have decided to stop working but the temp and fuel gauge still works, ive tried 3 sets of clocks that i know work and still its the same. so im thinking it may be the sensor in the gearbox. any ideas?
its a brm box if thats any help
thank you!
MissYasmine is offline
post #2 of 7 (permalink) Old 04-03-2017, 21:55 Thread Starter
bump, any ideas?
post #3 of 7 (permalink) Old 05-03-2017, 08:04
There are a couple of fuses dotted about, one for the speedo transducer and another one for the instrument cluster so I would start there.
As far as I can remember the speedo gets its signal from a transducer in the gearbox and the rev counter gets its signal from the ecu which in turn gets its signal from the alternator.
Did both gauges stop working together?
lsto is offline
post #4 of 7 (permalink) Old 05-03-2017, 08:09
Fuse 1 in the engine bay has something to do with the speedo.
Fuse 1 in the passenger fuse box does the instrument cluster, also fuse 3 says instrument and interior lights.
I'd start there, hope it's a little help.
lsto is offline
post #5 of 7 (permalink) Old 05-03-2017, 09:39
Doesn't the car have a speedo cable, I thought '99 would have made it pre digital speedo, the clue will be in the milometer, is that digital or analogue?
post #6 of 7 (permalink) Old 06-03-2017, 18:28 Thread Starter
Both the revs and speedo have both died together and its a 1999 rover 25, it doesnt have a speedo cable, ive checked 1 fuse ill try the rest when i get time, ive also bought a new transducer for the gearbox
post #7 of 7 (permalink) Old 13-03-2017, 19:22 Thread Starter
Ive been out on the weekend and all the fuses are okay, i also fitted a new speed sensor attached to the gearbox from rimmer and still nothing
Rover 420 Diesel 1998 Speedo dead thegrendal MG ZS / Rover 45 & 400 8 23-02-2013 21:27
Speedo Is Dead FezzyFox Rover 600 7 11-06-2012 12:37
T series rover 420 - Speedo dead Mr Flibble MG ZS / Rover 45 & 400 24 30-05-2007 05:31
Rover 75 ABS light, Dead speedo + ECU? tvrmadman MG ZT / Rover 75 (Sponsored by Rimmer Bros) 17 01-08-2005 09:19
speedo DEAD!! ja-mo4si Others 5 25-07-2005 16:20
