temp guage issues - MG-Rover.org Forums
post #1 of 8 (permalink) Old 21-08-2012, 09:00 Thread Starter
temp guage issues
For those of you who have had the old temp guage issues before the dreaded HGF,
Yesterday I had a long motorway journey, towards the end my temp guage went above half way but then dropped back straight to its original position of just under half, it did it 2 maybe 3 times but was only ever reading 'hot' for about 5/10 seconds.
Is this likely to be the early signs of HGF or is it more likely to be a faulty thermastat?
The only reason I ask is it didn't seem high for long which I would have thought it would if the engine was overheating.
Also I'm in grimsby atm so if anyone sees me give me a flash.
shaunbing is offline
post #2 of 8 (permalink) Old 21-08-2012, 09:15
Temp gauge sensor is different one from the ECU temp sensor. This 'jumps' on temperature readings could mean that temp gauge sensor needs inspection, and maybe replacement.
post #3 of 8 (permalink) Old 21-08-2012, 11:13
Car: R25 soon to be 1.6vvc
Sorry to jump on this thread but where is the temp gauge sensor? I have a problem with my gauge, whenever I give it the beans a little bit the temp gauge always drops really low before returning to the normal position, same happens if I'm coasting down a hill not using the accelerator
hughes07 is offline
post #4 of 8 (permalink) Old 21-08-2012, 11:44
What engine you have?
post #5 of 8 (permalink) Old 21-08-2012, 11:51
1.4, if its the one on the right on the coolant elbow off the block i've tried replacing this but i heard theres another one but cant remember where it is
hughes07 is offline
post #6 of 8 (permalink) Old 21-08-2012, 12:28
It is the one BELOW the one you described on the same pipe and position - just below. The one you mentioned is brown one and that is ECU temperature sensor. Gauge temp sensor is black or blue - facing down from the pipe. Brown one is facing to the radiator.
post #7 of 8 (permalink) Old 21-08-2012, 12:51
Is this same as the 1.1?
As we have a Blue one on the top and am trying to trace a problem (as per my other thread), what would happen if they got these in reverse, anything?
Beatonator is offline
post #8 of 8 (permalink) Old 21-08-2012, 16:32
Yes it is the same with 1.1 engine.
This is the same question I was asking myself if I can just use brown when I needed to change my gauge temp sensor. Point is these sensors do not have same part number and because of that I stick with the part numbers Rover recomended. I assume there should be reason why they did not use same part number for gauge temp sensor.
Until now I did not found relevant answer to this question so I can only guess, for now.
temp guage selwol MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 29-06-2012 18:55
HELP temp guage bomber harris MGF and MGTF (Sponsored by MGFnTFBITZ) 4 03-08-2010 17:04
What IS my temp guage doing?! stephen MG ZS / Rover 45 & 400 0 12-10-2009 23:00
major problem need help speedo/fuel guage/temp guage won't work! Boy-Racer ZR MG ZR / Rover 25, 200 & Streetwise 3 28-07-2009 21:48
temp guage-help watson54z MG ZR / Rover 25, 200 & Streetwise 0 03-04-2007 17:35
